The Monkey
Monkey See, Monkey DAC
A really sick dud
- Oct 28, 2004
So it appears that you came in here with an agenda, and not just a question about an amp pairing with the O2. Nothing wrong with that. However, it's more direct to just state your position. Like this: "I'm skeptical that amps make much of a difference with headphones, and I think that includes 'stats. Convince me otherwise." Dispenses with a lot of the circular stuff.
Regardless, the debate itself will not be resolved here. Like cables, if you don't believe it, you don't believe it. Further, if the 252 provides you with a satisfying musical experience, huzzah! You get to spend more money on music. I suggest just buying it, as you appear to remain unconvinced that you need to spend more. I also encourage you to attend a meet where you can hear some of the other amps, or pick up a 717 used (you'll have no problem reselling it once you find it is the same as the 252) to hear how they compare.
Originally Posted by SmellyGas /img/forum/go_quote.gif Well part of the reason some of us are skeptical that headphone amps make a HUGE difference in sound quality comes from experience in home audio. At least 10-20 independent trials have been published, including a summary review in JAES, that essentially pointed to the inability of people to distinguish between loudspeaker amplifiers when not aware of the identity of the amplifier. When it comes to headphone amplifiers, the cheapest ones (i.e. built in to a receiver) have measured problems with frequency response with difficult loads, so yes, they CAN make a difference. But once you get into the amps that are above CMOY quality, then I am not confident that the differences are as dramatic as people report. |
