Sarita Coshaa
- Nov 7, 2015
If you have developer options enabled on your phone, you can check there, under Bluetooth Audio Codec.
To enable developer options, go to settings and search "build number;" tap the build number seven times; a new developer options entry will now appear at the bottom of your settings menu; Bluetooth Audio Codec will be under the Network heading.
You might also be able to just Google your phone model to find out which codecs are supported.
Yeah I couldn't find that info, but google says it only has A2DP.
However, one of the dev settings say "Select USB configuration" and I can select "Audio source" as an option, also another setting says "Disable USB audio routing (Disable automatic routing to USB audio peripherials)". This seems strange for a phone that has no OTG and doesn't inspire me confidence to get a DAC for it to not work after all.
So, no DAC and the bluetooth codec is not good. Talk about bad luck uh...
