Sarita Coshaa
- Nov 7, 2015
So I have a phone, a low-mid end android phone from 2017.
I have some IEMs, and when I try to play something at low volume, there is a lot of background static noise that sometimes "eats" the sound, Idk how to explain it, like if the noise ate information and didn't play it. Like someone was whispering and you won't hear anything at all (other than static noise) unless they say a word with "s" which would be typically louder, then you'll hear a small "sss-" and then it would cut to static again.
Again, it's a static background noise, not white noise nor a hizz on the background per se, but it's similar to those.
It is less noticeable when using low impedance earbuds and it is completely gone when using bluetooth earbuds. Any clues as to what might happen?
Also, would an external DAC work for this problem? Taking into consideration this phone has no OTG capabilities.
Thank you!
Thank you!
