static noise with mki+
Aug 29, 2009 at 4:15 PM Thread Starter Post #1 of 4
witness
hi everyone,
i am using little dot mki+ with grado rs1. But i can hear static noise an right channel. Nothing on left side. also i noticed that the noise is starting after 5 minutes when i turned on the amp. I mean everything is normal at first.
What do you suggest me to do?
Is there any owner here who heard the same problem?
thanks.
Aug 30, 2009 at 2:08 AM Post #2 of 4
This is the portable one right? If it is it might be a faulty OPA or bad connection. I had a AirHead go south with the same symptoms not to long ago. I would just keep an eye on it for now. If it worsens, then contact LD.
Aug 30, 2009 at 11:04 AM Post #3 of 4
yes the portable one.first i didn't notice anything like that but now it is getting worse.
