Hello--
I recently acquired a pair of Stanton Sixty-Five four channel headphones. For whatever reason, all 4 speakers are blown out in them... I am in search of replacement drivers, and have it narrowed down to three different ones. I am just looking for opinions on them, or possibly another suggestion of speaker choice. Original driver diameter is 40mmx17mm(?) (dont remember depth, but there is spare room behind the speakers)
I havent decided how to wire them up yet either. There is a switch in one of the cables to go between stereo and quad (has two quarter inch plugs for quad usage), though I am not sure if stereo parallels the speakers or just disables two of them.
Also, would it be worth plugging the air ports on these, or possibly adding sound material behind the speakers? On my Sixty's, I ended up replacing the blown 2 way dynamic speakers with 2 way car speakers, and plugged the airports based off a really old forum post that said doing so really helps with lower frequencies. I don't have an unmodified set of sixty's to compare against, so I'm not sure if plugging the air ports helped or not...
#1: http://www.newbdnc.com/wp-content/uploads/datasheets/BFC-D45-7-32-012.pdf
I like these cause they have the lowest Fr, and have the most data available about them Frequency response seems decent as well. If they were paralleled, that should bring the resistance down to a reasonable 16 ohm.
#2. https://media.digikey.com/pdf/Data Sheets/Tymphany/HPD-40N16PET00-32_Spec.pdf
Similar to #1, though the frequency chart is blank :/
#3: https://www.mouser.com/datasheet/2/334/AS04004MR-N50-WP-R-1628387.pdf
Originally found these, though they might be a smidge too tall for the cup. Has a higher Fr than the other speakers, so useable audio range may be slightly less. Resistance is 4ohm, so paralleling these may not be the best idea.
I would greatly appreciate any input on the matter!
