Originally posted by rohorn
The terms are there to describe the TYPE of sliding, not how the sliding was induced.
I could push out either the front OR rear end of my Scirocco (RIP) by modulating the throttle at the cornering limit. And I did so often. Having a suspension properly tuned does wonders. |
Actually it has everything to do with how you induce oversteer. Notice you were using power (modulating throttle) to move the car around.
Braking to move the front of the car around still isn't oversteer. Whats more is you can't counter this type of slide by counter steering and applying throttle.
Physics....
Try this out: Take a quarter or a bottle top. Put your finger or a pen behind it (in the center) and push. Now, put your finger or pen off to one side. You'll notice that the object _goes_ in the other direction right? But notice another side effect, the object also rotates in that direction as well. Think of that as oversteer. That is the property that seperates it from sliding the nose around in a line, to oversteering under power. Try the same expirement by pulling the object from the front. Just doesn't work.
Having a properly tuned suspenion and chassis upgrades does wonders indeed. It helps the correct tires grip in the correct spots.
One must remember that while a vehicle might be capable of oversteer, that doesn't mean it is any faster at going through a corner. Think of it as merely and option to consider if you have too much confidence and take a corner too fast. It might help you miss the wall and stay on the track. Any situation where the tires break loose is a bad one. Any time you ask your tires to grip more than they are capable of means that you aren't transmitting all the power you are capable of.
If you require 100% of your grip potential to turn into a corner, then you can't apply any throttle. This hurts to front wheel drive, because the tires that are trying to pull you in one direction are the same ones responsible for making power. If you turn your tires in, the car will follow that path as long as the tires have a grip potential higher than the cars momentum fighting to keep it in the same line. You really aren't using all 4 tires to their maxium potential here.
Any time your tires slip, is a missed opportunity to push the car forward. It make look cool and be fun, but it is still the slowest way to go about it. (except in dirt, WRC rules!)
weee....
