artazzzzzz
- Aug 21, 2010
[size=medium]
Hello, I was always wondering what is the difference in what does SRS Audio Sandbox (Sound enchantment plugin) compared to amplifier (or headphone amplifier)?
I own Audio Technica ATH-M50 headphones. I also use SRS Audio Sandbox which gives me a huge difference in sound quality. I've never tried using headphone amplifier but I was wondering if I should give a shot? As I know amplifier improves signal that's going from the sound card to the headphones but don't some of SRS Audio Sandbox features do the same thing? It is said that the Sandbox is like a virtual sound card driver but why then it doesn't work without the true sound card driver?. If I increase the output loudness through the Sandbox above the normal level I can hear creaks and distortion, what means the signal sent from the card was too strong and my headphones can't handle it? Help me I am confused!
My questions are:
1. Is there going to be a difference if I will get an amp?
2. What exactly is SRS Audio Sandbox?
3. Is SRS only a plugin or an individual sound driver?
4. If you use SRS Audio Sandbox is your sound card driver still responsible for the quality?
Thanks for your responses
[/size]I own Audio Technica ATH-M50 headphones. I also use SRS Audio Sandbox which gives me a huge difference in sound quality. I've never tried using headphone amplifier but I was wondering if I should give a shot? As I know amplifier improves signal that's going from the sound card to the headphones but don't some of SRS Audio Sandbox features do the same thing? It is said that the Sandbox is like a virtual sound card driver but why then it doesn't work without the true sound card driver?. If I increase the output loudness through the Sandbox above the normal level I can hear creaks and distortion, what means the signal sent from the card was too strong and my headphones can't handle it? Help me I am confused!
My questions are:
