AutumnCrown
- Sep 24, 2015
I need feedback on a possible method of estimating loudness of headphones. My goal is to make estimating volume levels doable for anyone with access to headphones which can be equalized to a given target.
The methodology is basically to create two tones with the following generator, one at 30 hz, and one at 1000 khz, with the same SPL level.
https://www.audiocheck.net/audiofrequencysignalgenerator_sinetone.php
I then adjust volume until I can barely hear the 30 hz tone. Then, according to the contour, and assuming my hearing is undamaged and relatively normal, the 1000 hz tone should also be about 60 decibels, and repeating the test with a 20 hz tone should leave the 1000 hz tone be at about 70 decibels.
My problem is I am not sure what target response of the headphones should be equalized to. I assume it should be somewhere around the Harman target, but then again, perhaps the diffuse field bass response would be more "spl-flat" between 20 hz and 1000 hz?
