gregorio
- Feb 14, 2008
[1] So, for example, a particular sound may be more or less "audible" depending on whether our brain finds it "interesting" or not.
[2] When you walk down the sidewalk, you most certainly don't see every speck of gravel on the walk.... but every one is visible IF YOU CHOOSE TO LOOK AT IT.
[3] The bottom line is that lossy CODECS do omit content...
[4] And, since they do so based on masking theory, WHICH IS NOT 100% UNDERSTOOD, there remains the possibility that they will inadvertently cause an audible error.
[5] This makes using a lossy CODEC "more risky than using a lossless format" (because, with a lossless format, since nothing is omitted, there is zero chance of omitting anything important).
[6] And, personally, when asked whether I'd like "the real thing" or "a copy that's so good you're sure I won't notice the difference" - I'm not going to consider the copy unless there is a compelling reason.
[7] And, with storage space and bandwidth so cheap these days, I don't see a compelling reason to choose the option that's merely "probably audibly just as good".
I'd absolutely rather have ALL THE SIGNAL than just some of it.
[7a] Why should I have to worry if the part I have is good enough ...
1. You accuse others of "cherry picking" and then do exactly that yourself. Your statement is true but EQUALLY true is the statement that; a particular sound will always be inaudible regardless of how "interesting" the brain would find it.
2. Clearly that statement is FALSE! Are you really saying that "IF YOU CHOOSE TO LOOK AT IT" you could see every spec of gravel? You "walk down the sidewalk" with a microscope bolted to your skull do you? If not, then no matter what "you choose to look at", you're NEVER going to see ANY of the microscopic specs of gravel.
3. No, that is NOT "the bottom line" because ALL recording and reproduction technology "omits content", including; Microphones, lossless codecs, speakers/HPs, amps and of course content is deliberately omitted as part of the recording and mixing processes, by the engineers and producers. The "bottom line" is therefore NOT that content is omitted, because it's ALWAYS omitted, it's what audible difference that omission makes.
4. There is always the "possibility" of pretty much anything. It's "possible" that every sub-atomic particle in your body could relocate simultaneously and that you could vanish and reappear somewhere else in the universe. However, it's an incredibly slim possibility and has never reliably been observed to occur. Have you ever observed it? Have you ever encountered an audible error with a modern high bitrate lossy codec used on commercial audio content? How realistic a "possibility" are we talking about?
5. Firstly, your reasoning is based on a fallacy, because content is omitted in every recording, including those in a lossless format. Secondly, "more risky" in theory or in practice? For it to be more risky in practise, you would have to show that there are at least some practical examples, because with no examples the probability is zero and therefore there is not "more risk".
6. This too is a nonsense statement/analogy. You cannot have "the real thing", you can ONLY have a copy! I take it you are not suggesting that Emotiva DACs are packed with hundreds of tiny musicians? In which case, your choice is NOT between "the real thing" and a copy, it's between one copy and another copy, so if you are "not going to consider the copy", what is it that you're actually trying to reproduce?
7. This isn't the "What KeithEmo sees as a compelling reason" forum, we therefore have to consider what probability of "audibly just as good" we're actually talking about. Do you have any examples of music recordings (with a high bitrate modern codec) not being "audibly just as good"? If not, then you have no evidence or logical rationale for anything other than a 100% probability that it will be "audibly just as good"!
7a. Unless you've got some examples/evidence, then you have no logical reason to worry. Of course, it's up to you if you want to "worry" based on some illogical reason or no reason at all but this is the sound science forum not the "what KeithEmo illogically worries about" forum!
A large percentage of audiophile marketing is based on generating a fear of some "possibility", a possibility which is so remote as to never actually be encountered by consumers and/or which is in fact inaudible anyway. So I understand your position; why you have to generate fear, conflate a "possibility" with a probability and cast doubt on "inaudibility". However, this is the sound science forum and despite being reminded of this fact numerous times, still you insultingly treat it as your marketing forum! What you don't appear to realise is that not only do you pervert this forum with your misrepresentations/obfuscations but you also harm your brand/marketing when your misrepresentations/obfuscations are exposed, so why do you carry on doing it?
G
