antonyfirst
Oh, god. So also the GB9 has white noise.
Originally Posted by Assorted Yes it is gapless on all formats (shouldn't they be?), and I don't think the 355kbps WMA firmware update applies to the HD30GB9. |
Originally Posted by Dorder /img/forum/go_quote.gif are you sure it's gapless on mp3, since there are gaps with my lame 3.97 api files which aren't there with kenwood lossless? if yes, what codec and firmware are you using? |
Originally Posted by calyx /img/forum/go_quote.gif In fact I am having a hard time trying to understand why Kenwood comes up with its own format instead of supporting FLAC. To do it I can think of a few possible reasons and none is reasonable at all : - more compression : yes, but a tiny fraction compared to FLAC. Not good enough. - more battery friendly decoding : this seems not tru, I am sure playing FLAC would not drain considerably more power. what else? Furthermore, you can not play kls files in computer. You can not play even the supported files (mp3, vaw, wma included) in the DAP if you just dragdropped them from the computer bypassing Kenwood media application. I am not even sure if KLS supports tags , album art whatever. It should but no info anywhere. What is the benefit of Kenwood Lossless over FLAC? I wanna know what good does Kenwood Lossless serve? |
Originally Posted by isamu /img/forum/go_quote.gif Dorder....I notice in your sig it says "portable: hd30gb9/njb3-> e500/er4p/cx300" does the njb3 stand for Nomad Jukebox 3? If so, how would you compare the SQ between the Jukebox 3 and the Kenwood hd30b9? After reading how the hd30gb9 doesn't have a line out, and doesn't allow you to play mp3s, wmas, etc, I would find it very hard to justify replacing my Jukebox 3 with the hd30gb9. |
Originally Posted by Sparky191 /img/forum/go_quote.gif Bad case of Sonyitis |
Originally Posted by calyx /img/forum/go_quote.gif I am not even sure if KLS supports tags , album art whatever. It should but no info anywhere. What is the benefit of Kenwood Lossless over FLAC? I wanna know what good does Kenwood Lossless serve? |
Originally Posted by Assorted /img/forum/go_quote.gif KLS is supposed to be for wav users, so naturally they don't support tags. |
Originally Posted by Assorted /img/forum/go_quote.gif KLS is supposed to be for wav users, so naturally they don't support tags. You're hearing gaps? Are they like *ftst* static or like an actual space in time? |
