flyer1
- May 18, 2009
Could we say the N3 is a mini Z1R?
Just bought N3, looking forward to use them with my WM1Z and Sony Kimber cable.
Maybe a bit more bassy than Z1R if reviews are correct?
You may like 3.02 firmware update as it is possibly the best way to use the N3 and 1Z together. 3.02 update is the most midcentric, but also has the biggest soundstage for the 1Z. Be careful joining the Kimber/Sony MUC-M12SB1 as times it was really grips the MMCX. Actually I’ve never joined the cable with the N3, as if I did I would never try and remove it.
But the N3 IS slightly more bass heavy than the IER-Z1R and XBA-Z5. Though it’s really a one of a kind fit and sound. Enjoy!
What eartips are these?You may like 3.02 firmware update as it is possibly the best way to use the N3 and 1Z together. 3.02 update is the most midcentric, but also has the biggest soundstage for the 1Z. Be careful joining the Kimber/Sony MUC-M12SB1 as times it was really grips the MMCX. Actually I’ve never joined the cable with the N3, as if I did I would never try and remove it.
Thanks, do they have any specific impact to the sound?RHA Double Flange L
https://www.rha-audio.com/se/products/accessories/double-flange-eartips-large-replacement
They make a great fitting IEM fit even better. IMO
As long as you use wide bore tips with good seal you can't really go wrong. Wide bore make such a difference to N3, they punch well above their price point IMO. I'm struggling to let mine go!
I was curious for something which could eventually reduce the bass impact...sometimes I feel is hitting too hard.As long as you use wide bore tips with good seal you can't really go wrong. Wide bore make such a difference to N3, they punch well above their price point IMO. I'm struggling to let mine go!
