ledzep
Yesbtw if you do an EQ on the Headphone app, does the BT connection go to SBC instead of LDAC?
I really like real leather touch of my P7W and I would love to try these on XM3's which I ordered. I've just had a look Dekoni sheepskin listings on Amazon, but I saw a few different types. Could you please share the link the one that you are using?
https://www.amazon.com/s/ref=nb_sb_noss_2?url=search-alias=aps&field-keywords=Dekoni+Sheepskin
I think that's down to a wedge of damping foam over the driver which I found odd, I'll be messing with them later see I that flabby bass can be tamedI would love to learn if 3rd party ear pads could lower the "fat" bass levels. Just a bit too much bass and sub bass for my taste. Its a bit too "pillow-y".
AAC is the only codec that does not cause the headphones to drop to SBC when the Sony EQ is on.btw if you do an EQ on the Headphone app, does the BT connection go to SBC instead of LDAC?
This is great, thanks for sharing. If you open them up again, would love to see a photo or two of how the Dekoni pads fit into place (they look super comfy, and it sounds like they make a good sonic difference right away).Once you remove the pads you'll either have to remove the black pad otherwise you'll have to layers as the pads come with driver guards or cut out the one on the new pads. I just took off the ones on the headphones they just peel off as they have a small piece of double sided tape on them and underneath there is a piece of damping foam covering the driver and filling the side gaps in the cup, I'm not too keen on this and will be trying out other methods of damping that doesn't cover the driver front as much and you'll have to make a few cuts in the new pads surround as the fitting ring has clips and guiding nubs that fit into the cup to hold it all together. Never been a lover of wireless headphones but I need a pair for work so after a bit of research the M3's sounded just the ticket for me, but I'm sure I can mod them to extract that bit more.
No I mean there is a piece of foam that Sony have put inside not me, I'll be taking that out later and modding them with some stuff I used on a pair of Sony Z7's and some AM2's to sort out that flabby bass. It's Sony's typical sound signature even my Z1R's had it until I modded them, don't get me wrong I like the Sony signature just that at times on certain pieces of music that extra deep bass can be a bit too much, it just needs reigning in a touch.Sounds bit like a few too many dbs of 80hz roughly. I am not certain a small piece of foam could fix that (but I am new to headphone hacks)
Asking for a little help. I've been out of the portable audio game for a little bit and looking to get back in. I recently purchased the Sony NW-A45 and am looking for some headphones. In the past I've really enjoyed the Sony MDR-1A; I've narrowed my choices to the MDR-1AM2 and the WH-1000XM3. Based on sound alone how do these two headphones compare? Thanks.
