I can see how this shape of tips might not fit some ears. Quiet similar case with Dunu S&s tips. Anyway i also like how xm5 sound with sony silicon tips ep-ex11. It give more midbass and warmer overall unfortunately it have no wax protection.
This new update change the soundsig quiet a lot IMO i like how this TWS sound now unlike before. It is smoother warmer but the upper frequency is not lacking in soundstage and details. I dont touch the EQ at all. Very enjoyable and very good!
I have not experience this issue until today.
This new update change the soundsig quiet a lot IMO i like how this TWS sound now unlike before. It is smoother warmer but the upper frequency is not lacking in soundstage and details. Very enjoyable and very good!
Spinfit Large CP360 have worked for me, stock foams are just a bit too small and the medium CP360 fit fine on my XM4, I had to size up to the large with the XM5.
Measured the nozzles at 4.7-4.75mm. Got some 4.7mm adhesive nozzle mesh to use as dust/wax protection with different ear tips. I'll report back once I try them.
Noticed some Azla tips with earguard 40% off in Amazon UK black friday so even though perfectly happy with my usual Spinfit CP100 and nylon stocking filter, I ordered some.
Went for MS same as Spinfit and slightly wider body, shallower depth but fit like a glove and test seal great with Sony App.
The silicon is thicker overall and I think gives more isolation and a bit more weight, bit less treble.
Colour matches my grey/white XM5 perfectly. Will stick with them as wax guard great.
Some pics vs Spinfit with stocking guards
Bits of black fibre from the stocking filter falling apart! Not dirty
