Devodonaldson
As sony music app doesn't go through the android audio stack, I'm pretty sure that via Bluetooth, music played through Sony app also isn't affected by Android, unlike other audio apps
Turn off when not in use relies on the proximity sensor in the buds so they have to be removed from the ears to do any good as far as I’m aware.After a month or so of heavy usage, I love the convenience of these (and the sound of course).
Some questions:
-I fall asleep with these in every day now, listening to audiobooks. My audiobook player has a sleep timer of 45 minutes, is there any way to have the xm4's turn off as well? I have 'turn off when not in use' checked in the settings, but I wake up with like 10% battery every morning after a full charge... Do these actually have to be disconnected from phones bluetooth in order to turn off fully?
-When I connect to my phone, the volume switches to max volume.... does this happen to anyone else? I THINK, it's because I've been using a bluetooth adapter for my Nintendo Switch (definitely not at full volume), and when I switch back to phones bluetooth it's just not sure what to do?
-On that note, the nintendo switch bluetooth quality is garbage... probably just the adapter I picked up for it, but it's reallllllly bad. Anyone else have experience with USB-C adapters?
-Last question! Has there been some tip rolling comparisons and suggestions? The hybrid foam tips are OK, but looking for something like silicone that will tighten up the sound a bit.
Thanks! I know I have these lyin' around somewhere... someplace... lol. Also i really don't mind the passive isolation suffering as they used mostly at night.I use SpiralDot++ which gives the best sq for my ears but suffers on passive isolation compared to foam tips
It's probably using SBC, which may not be supported all that well by the XM4s. You may have better luck with a dongle that supports AAC though that may also introduce a little bit of lag. I'm not sure of any dongles that support LDAC.On that note, the nintendo switch bluetooth quality is garbage... probably just the adapter I picked up for it, but it's reallllllly bad. Anyone else have experience with USB-C adapters?
Some questions:
you sir are 100% correct. the adapter does support aptX but the sony's do not, hence defaulting to SBC. (I am using the Homespot Bluetooth 5.0 adpater)It's probably using SBC, which may not be supported all that well by the XM4s. You may have better luck with a dongle that supports AAC though that may also introduce a little bit of lag. I'm not sure of any dongles that support LDAC.
I've got the Genki adapter and have paired it with my AirPods Max (which also defaulted to SBC) and it sounded pretty good, and with minimal lag.
Best of luck! In my previous testing of the Genki and other headphones (PX7, Aonic 50) both AAC and aptX sound pretty great, they just introduce some perceptible lag.you sir are 100% correct. the adapter does support aptX but the sony's do not, hence defaulting to SBC. (I am using the Homespot Bluetooth 5.0 adpater)
Taking a look at the Genki and both the Genki and Sony's support AAC, but many of the reviews are saying they are having troubles actually using that codec.
The SBC is OK.... definitely don't notice any latency or lag, just loads of distortion esp at medium-higher volume levels. I may give the Genki's a try, and see if I can get the AAC to work.
thanks for the info!
This is also phone (transmitter) dependant. All 3 Pixel phones I've had all seem to have good Bluetooth stability, or strength or whatever you want to call it. On the other hand I've had OnePlus phones that couldn't even keep a stable AAC Bluetooth connection. Back a couple years ago I had used the original Galaxy Buds on a OnePlus phone and had tons of audio dropouts and stutters, the same Buds in the same conditions connected to a cheap Pixel 3a had no audio dropouts or stutters. I've been forcing the WF1000XM4/Pixel 5 to the highest bitrate and have been having very very few stutters. I think the last week I've used them I've had one audio stutter while walking my dog and that's it.Went for a walk outside for the first time with them. Left bud would cut out for a second every couple of minutes. Switched from Audio Priority to Connection Priority and no issues after that. No ANC, ePro EP00 tips, volume was at default (Blue/Red).
Using Note 9, so yeah a bit older phone. Probably going Pixel 6 Pro once it releases.This is also phone (transmitter) dependant. All 3 Pixel phones I've had all seem to have good Bluetooth stability, or strength or whatever you want to call it. On the other hand I've had OnePlus phones that couldn't even keep a stable AAC Bluetooth connection. Back a couple years ago I had used the original Galaxy Buds on a OnePlus phone and had tons of audio dropouts and stutters, the same Buds in the same conditions connected to a cheap Pixel 3a had no audio dropouts or stutters. I've been forcing the WF1000XM4/Pixel 5 to the highest bitrate and have been having very very few stutters. I think the last week I've used them I've had one audio stutter while walking my dog and that's it.
I don't think it has anything to do with it being older.Using Note 9, so yeah a bit older phone. Probably going Pixel 6 Pro once it releases.
