My revised tip preferences: SpinFit 360, Azla SednaEarfitLight Short, JVC SpiralDot++, Sony stock tips. The SpinFit tips are the brightest, with excellent integration across the spectrum; I also find them to be the most comfortable. The midrange on these is probably the clearest and cleanest of all. The soundstage is the most integrated, with great focus on the instrument and vocalist location left to right. They seem to let the port extend deeper into my ears than the others. The Azla tips' highs are a bit disjointed from the mids and the soundstage seems to be more left or right with lesser placement across the stage. The SpiralDot++ tips don't seem as integrated (the mids seem almost separated from the highs). The Sony tips isolate the best, but are dark and the sounds are increasingly muted as the frequency goes up.
Based on LDAC, sound quality prioritized, from my WM1A, with high resolution AIF files of live and studio recordings. Some moderate midrange to high boosts for all listening.
Fit tested first using my iPhone and the Sony app, then changed to the WM1A for listening (the connection to the WM1A is almost instantaneous).
