RockStar2005
Yes the S5 sounded a lot more natural, there was not much difference.. the DAC what about the Amplifier chip ?
I know its a crazy thought the idea that a player this expensive would sound no better, I wouldnt say it sounded much worse either.
With something like amplifiers eg "Class-A" over the usualy "Class-B" ive noticed massive diference but know theres only one or two DAP's on the market that have a Class-A output stage and they are out of my price range. Also usualy there is a big diference in MP3 vs Lossless. on the A17 I did not notice that so much only a little yet on the Samsung Galaxy S5 it was much more in your face.
Yes I used the A17 with nothing enabled, as plain as you can get it but still no change.
My headphones were Musical Fidelity EB33, maybe that was the issue ? doubt it though
Well DAC and amp too. I didn't mean to imply the amp doesn't matter, but most ppl on here seem to focus on the DAC so I tend to also. lol
Not really crazy, I just don't know if I'd agree. I'd have to listen myself to determine it. However, I HAD at the time (pre-A17) bought the cheaper iBasso DX50 ($200) and pitted it against my Z3, and I too like you couldn't hear a difference. HOWEVER, after returning that I bought the $300 A17 and I could most definitely hear differences, esp after applying the settings I linked you (which has you noticed was originally posted MUCH earlier in this thread).
Oh yeah, when studios release albums, it seems from my experience that the mp3 version always sounds the worst, and is much more prone to "sound deficiencies", even at 320 kbps (i.e. the wishy-washy sound of cymbals, which are usually a dead giveaway that you're listening to an mp3). That's why in that link if you kept reading my post, I mention Hi-Res music and how to find it, download it, convert it, etc. I find that higher-up AAC files sound NO different than lossless FLAC/ALAC files if they're from the SAME source. Since AAC are next-gen mp3s (thus their other name.......mp4), they are made to sound better. The truth is, the Hi-Res files sounding better b/c of the higher resolution is just marketing BS. The REAL truth is the Hi-Res ones simply have BETTER masters. THAT'S IT. It took me a long time to accept that, but I'm happier and better for it. Saves me so much money & time to not store those huge ***** files on cloud and phone. lol
I've read about studies done that prove that statistically people can tell a difference from mp3 vs. lossless, but NOT aac vs. lossless. They say 256 kbps-320 kbps AAC files can achieve this, but I encode all mine at 512 (CBR) kbps, just to be a lil safer. lol So as long as my SOURCE file is Hi-Res, converting it down to AAC using dbPoweramp (NO relation to Poweramp btw) makes NO difference in sound quality to me. I've tested this myself many times, even doing so using the ABX Test, and I could not tell a difference. I was storing my files as ALAC (and putting AACs on my phone) b/c they say doing that "futureproofs" them so if a new format comes out, you can convert to it w/o issues b/c it's lossless. But it takes up too much space, and I can't really imagine a new format coming out that will sound any better (and that I could simply "convert to"), so I'm in the process right now of converting all my backups to AAC. F it. lol
Ok. But did you raise the 2.5Hz EQ band up 2 notches like I did too? Doing so made the vocals stronger and gave the drums more weight.
Didn't know those, so I had to look them up. Yeah, I would say that is MOST DEFINITELY the issue my friend. lol Earphones......to me, simply can't do what headphones can do, and most def not $83 ones like the EB33. I had $30 V-Moda earphones b4 and thought I was cool lol, but looking back they didn't even come close to what my headphones can do. You simply hear more detail, experience wider & most vast soundstage, etc, on really great headphones. After trying out SEVERAL premium headphones priced b/t $140-$400, it was apparent to me ONLY ONE gave me everything I was looking for.........a neutral/balanced sound, excellent clarity, bass is there but NOT overpowering, soundstage is HUGGGE, premium looks, great comfort, etc..............the AKG K550 MK II! And for that price ($140-$150), it was a no-brainer to buy it (I even got the $20 3-year warranty). They sounded better than even a few of the $400 headphones I'd tried out. Yup......it's the truth. I couldn't recommend them more! I pair them with my Oppo HA-2 premium amp/DAC, which is also beyond amazing, and play off my phone (Sony Xperia X Performance).
Since you are open to Android and don't want the A17, I would recommend you look into my setup for you. You can stack the HA-2 with your phone, or consider alternative amp/DAC options like the AudioQuest DragonFly Black v1.5, AD Red v1.5, the xDuoo XD-05, etc. The last 2 are considered by some to be better and cheaper than my $300 HA-2, but others disagree. I can't say as I don't know. The HA-2 is the sleekest and nicest looking of them all, great options, rapid charging, etc.
