Sparky191
- Apr 17, 2005
I heard it only works with Synch and not with drag and drop? Is this true?
Originally Posted by gastro54 /img/forum/go_quote.gif As long as you can see the album art in the bottom left of the MM window for your songs, MediaMonkey will sync it correctly with the A818 |
Originally Posted by chongy5 /img/forum/go_quote.gif For those using MediaMonkey, how do you put videos on the device? My music is synced using MediaMonkey, but I tried to drag and drop a (as far as I can tell compatible) video file in the VIDEO directory (where the Spiderman 3 trailer is) it just doesn't appear. I figured it was because Mediamonkey was controlling the sync. Any way around this? Does mediamonkey have a video option? I couldn't see any after a quick look through the menus. |
Originally Posted by grommal /img/forum/go_quote.gif My guess is that your video files were not really compatible. |
Originally Posted by chongy5 /img/forum/go_quote.gif Yeah that's what I'm still thinking, but I just figured that even if they weren't compatible they would still show up on the video library list, and then if I played them from there they would THEN fail. What settings did you use? Do you think the fact that I used 25fps rather then 29.97fps have any difference..... |
