Vitaly2017
Anyone did comparisons of zx500 vs cayen n6ii and wm1z?
Are there any of you who knows how the sound is compared with zx2?Sound wise this thing is very near the WM1A....so my WM1Z is definitely better to my ears.
It is but the ZX2 is still very impressive in its own right if operates within the available driving power.i had zx2 and moved to wm1a and found it quite an improvement , so zx500 is probably an improvement over zx2 as well
Most lithium-ion batteries only get up to 500 full charges before they start to go out. I think I might have gotten 500 days of use out of my Hiby R6 before its battery gave up the ghost, and it had gone through at least 300 recharge cycles. I doubt any player on the market now will give more than 3 years of good battery life (even with light usage), but I wish you luck in the search.
FYI, the ZX-507 will charge in about 2 hours with a PD/quickcharge 3 charger.
The whole battery lifespan issue is the major reason I don't buy expensive DAP's. Spend $300 on a DAP it lasts two years amortized to $150 per year. Spending more then that over two years I start to feel more cheated financially the more I spend. My larger audio purchases are strictly for home audio gear which last alot longer with a much bigger bang for the buck.
Some chase the best portable sound regardless of cost, I go for the best sound for my budget. I have never spent over $300 on a DAP, A17, Shanling M0 (sold for full price) Fiio M7 (demo model, saved $50) will sell in the new year. Current DAP Fiio M9 got for $120 off on Black Friday, paid $279. Shanling M0 sounded pretty good for the price but to small, Fiio M7 sounded very good for the money, if it wasn't for the great deal on the M9 I would still be using it now.
Sony A105 is listed for $480 CDN on sony.ca, way out of my budget and not enough power. Stripped down android on the Fiio M9 not perfect but it is more than fine for Pulsar and ES File Explorer, don't use wifi or streaming. If the M9 lasts a couple of years it will be a very good investment and it does sound really good. The extra power provides very good headroom and improves the dynamics.
It isn't just enough to have adequate power to drive headphones. To do the music justice you need the extra power in reserve (headroom) for those short bursts that dynamic sounding tracks require. The A105 might drive my headphones okey but the dynamic headroom simply won't be there with such a low power output.
About the same or slightly more. I guess it's an Android thing.
ZX507 is a major step up from ZX2 interms of audiophile(DSD/24bit lossless files) sound quality. You won't regret going for this upgrade. Please do use Balanced Connection to maximize the most performance out of the ZX507.
You get:
120 levels of volume control and low/high gain adjustments
A more responsive user interface
Modern Streaming app support
Faster Wifi
Better physical buttons(more tactile)
About 3x more power output on single ended.
Balanced output which really does sound really magical with Sony IEMs.
Much deeper and more stronger bass.
A much smoother mids and a more richer sounding treble.
Adjustment of bass response via DC Phase Linearizer
3D(height) soundstage with DSEE HX
Equalizer that does scale up and down more noticeably
AAC and Aptx HD Bluetooth.
Almost near instant boot time.
Database don't require updating each time you power up.
Much more lighter and fits in any small pockets
Charges much faster via USB-PD(it takes 30mins to get from 5% to 50%)
USB-C uni-direction ease of plugging
What you lose:
A smaller screen
Less Battery time and standby time isn't as solid as ZX2(it loses % more per day)
No search function
i listened to ak se100 and sony wm1A with my mdr 1Am2. wm sounded perfectly except I can't add bass through EQ when I listened to hip-hop, like I can do on my iphone.disagree w this tbh
tried Z1R and M9 on balanced vs non-balanced for ZX500, SP1000M and SE100
literally no difference apart from the volume being alot lower on balanced (ZX500)
can u elaborate what the audible differences are if any
ak 100 had the same problem of dead EQ. overall it sounded not impressive at all. moreover, on high volume music sounded clogged and awful like on iphone. both players are too big to be put in a pocket. ak has also idiotic design with sharp edges.
people here say that zx500 is a clear improvement of zx300 in terms of SQ, and it sounds almost as good as wm1A.
Luckily I have a Sony spot in Tenafly NJ near me that can swap a battery if needed.
