Actually, the WM1A is no slouch on it's own. I use it daily with my XBA-Z5 and a Norne Audio Therium cable, and I cannot for the life of me find anything wrong with this sound. It's really as good as it gets. Getting the WM1Z is likely not just a matter of preference (negating the price difference), but if you take the WM1A on it's own, it'll fill several needs already. So unless the WM1Z is really just a fraction more expensive, there's no reason to think of upgrading from a WM1A.Very interesting to hear. So far it seems WM1Z is the choice for sound even if it would cost a bit more.
I've mostly listened to the WM1Z so far so cannot make any final conclusions but so far it's just something with the sound of hte WM1Z that sounds just right, and the limited testing of the WM1A is that it's great but it's just not the same.. but as always the difference is not big and possibly wouldn't be noticed without comparing back to back..
I would for sure pay 500 euro extra for the WM1z or a bit more, but not 1500euro which is the case now.
However a note on portability, i actually find no issues with having the WM1Z in my jeans pocket or jacket. And also the weight just adds to the feeling of quality, and you can defend yourself with it if attacked
SONY NW-WM1Z / WM1A
- Thread starter leylandi
- Status
- Not open for further replies.
proedros
very happy with WM1A , a definite improvement/upgrade over ZX2
if i had known how good it is , i would have upgraded from ZX2 months ago but some people said that wm1a was like zx2 (such a wrong assessment) and this stalled me from buying it
aisalen
- Mar 17, 2017
Nice! Thanks.Yes mine has not been turned off in the 7 months I’ve had it just like my ZX2 was not turned off in nearly 2 years
aisalen
- Mar 17, 2017
Totally agree, it is an end gamer for me. Better in all angles and in sq compare to my previous and current rig which is X5 1st gen with E12A, Aune M2 Pro and Opus #1. On this player that I experience like I am in inside the room together with the performers.Actually, the WM1A is no slouch on it's own. I use it daily with my XBA-Z5 and a Norne Audio Therium cable, and I cannot for the life of me find anything wrong with this sound. It's really as good as it gets. Getting the WM1Z is likely not just a matter of preference (negating the price difference), but if you take the WM1A on it's own, it'll fill several needs already. So unless the WM1Z is really just a fraction more expensive, there's no reason to think of upgrading from a WM1A.
blazinblazin
- Nov 19, 2015
I upgraded to WM1A from my X5II with E12A.Totally agree, it is an end gamer for me. Better in all angles and in sq compare to my previous and current rig which is X5 1st gen with E12A, Aune M2 Pro and Opus #1. On this player that I experience like I am in inside the room together with the performers.
I like the space feeling that WM1A gives too~
The depth the slight echo effect i experience in some of the sound in the music created a nice ambience feel.
Some tracks i can feel the sound/vocal directs towards me from soft to loud then fades away with slight echo.
gerelmx1986
I already find the Sony UI brilliant, so no need to changeAnyone else wished to see Sony adapt a UI more like AK? I love to have the sound of WM1Z with UI of my AK70.
Quadfather
Is it just me, or does 96khz - 24bit sound better than 192khz - 24bit on the Sony NW-WM1A?
CobraVerde
- Oct 16, 2013
So I spoke to one of the designers of the WM1Z at the indulgence show and the features are coming in NOV.
blazinblazin
- Nov 19, 2015
Looking forward to the update.So I spoke to one of the designers of the WM1Z at the indulgence show and the features are coming in NOV.
captblaze
Many variables dictate that. The entire recording, engineering and mastering have an effect as well as
which wrapper it is all stuffed in. I have Redbook that sounds awesome and some that makes mono vinyl sound hi res. Its all a crap shoot
all999
What features?
blazinblazin
- Nov 19, 2015
I have 320kbps MP3 that sounds phenomenal.Is it just me, or does 96khz - 24bit sound better than 192khz - 24bit on the Sony NW-WM1A?
I can't believe if was MP3 file.
Mastering and Recording is more important than anything else.
nanaholic
- Sep 2, 2010
Heck no. AK players is just Android, the cross bar Sony UI is way more intuitive. I really like the ability to flick up/down/left/right and have access to all the most used features.
There's one thing that I wish they would add though - the ZX300 has repeat/shuffle button on the main player screen which you can tap to cycle through the modes instead of the current "setting>repeat/shuffle" selection. That I wish they would bring over.
CobraVerde
- Oct 16, 2013
What features?
MQA, APTX HD Deffs
I forgot to ask about computer dac.
Also got a WM1Z for £2000
arftech
- Dec 3, 2010
If it can’t stream Tidal or to a lesser extent Spotify then I’m not interested. LOL
- Status
Total: 13 (members: 0, guests: 13)
