bana
- May 21, 2014
This where I got mine from, bought via buyee
https://store.shopping.yahoo.co.jp/e-earphone/4589962103319.html
Thanks.
Hi Matrix, I am in Perth, where are you located?
Can somebody please share their experience with remote control for WM1? Worth to buy?
Ups I didnt read it properly . That's what happen when reading forum at 3AMHi, rtjoa
I am in Vilnius, Lithuania. By virtual audiophile emigration to Australia I meant that I decapped my WM1A from EU version to Australian. Please believe me, Australian sounds much better and louder.
By the way, maybe good idea to emigrate in flesh - getting colder here in Lithuania, despite all that global warming.
I can't live without the remote after i had it.Can somebody please share their experience with remote control for WM1? Worth to buy?
Hi guys
I must say balanced output with 1A just sucks , i have experienced terrible background hum , also when i play to dsd files i get pop noise every each time i scrolling or changing a track , second thing is another pop / crackling noise when i change files formats for example from dsd to flac or flac to dsd or frequency is changing it happen even on both outputs !!! Last issue always appear when changing volume level pop sound each time i click on volume button , very weird is that only can hear this between 0-50 , then 50-70 pop sound while channing volume doesn’t exist at all , and the. back on 70-120 What , what is wrong wih that device ....
Hi guys
Hi guys
I don’t think so , if other people have a same experience . It’s really shame that expensive device behaves so odd .... Also same here i haven’t got any hum or pop / crack sound with my HD800 ( except balanced ) , even HD800 on balanced behaves same as other my iems ... I’m currently on Rose BR5 mk2 , they are very sensitive iems , but that much background hum i’m getting through balanced output simply disclaims me of comfort listening experience, i can easy forget about listen to the jazz because of that .... SE output no background hum ( white noise however you call it ) only those pop crack sound wih volume and dsd ... Sony has disappointed me ...Sounds like a faulty unit. The pop you get between flac and dsd is not actualle changing fileformat but happens when you change between the 2 clocks so between multiples of 44 or 48
Hi guys
My WM1A is set to All Songs + random.
So depends on mood i will skip songs.
I had finished 2 battery since i bought it. I am on 3rd remote battery.
