So I just received the WM1A player today. Ran the "info" from Rockbox and it said the unit had the volume cap off even though the unit is CEW2 (West Europe) - shouldn't the volume cap be on by default? The volume goes to 120 steps. How high does the units with the hack enabled or the units outside Europe go? It doesn't have the high-gain output setting. Am I missing something? I have the unit up on 120 to have it high enough - It's okay, but I think I might like to go a bit higher.
No it doesn't have that - as I can read only the "E" version has this (Asia / Australia / NZ / Tourist) which was what I was going to change it to. Just wondered why it says OFF under Sound pressure. Have tried to upload the info I get when I run the batch with GET.
We don't know why this is, but what is important is the destination setting. Once you set this to one of the appropriate values, you will have High Gain available.
OK - so that's what will enable higher volume overall? I remember this from my Denon DA-10 amp/dac - it has a high/low grain where the volume goes higher.
The volume won't go to a higher maximum number, but what is output for a given number will be, err, "more powerful" if that makes sense!
I just thought that the sound pressure was equal the volume cap, so I was confused as to why it was set to off. My bad I'm returning the NW-WMA1 as I just found it on Amazon.co.uk (via this thread - thanks!) about 300$ cheaper then what I paid here in Denmark. So I won't do the change before I get the new unit..
From memory, the only important setting is the destination code. I seem to remember the documentation even mentions that the sound pressure setting does not have any impact on the the volume cap; changing the destination to one of the right codes simply makes High Gain available. I'm pretty sure I just changed the destination to the East European setting, and didn't touch the sound pressure setting.
Interesting device, but wow, expensive. Didn't care so much for the thick sound from the zx2 I sampled, but I think it had the eq settings on at the time. I'd really have to have a listen before dropping that much of my retirement fund... Anybody know where I could audition one around Phx, Az? Upgraditis... Thanks for your help, Drew
I am waiting for your WM1A review since weeks now. Now with both players on hand it gets even more interesting.
@mw7485 thank you. I will enjoy it even with a limited time. @pietcux My WM1A has a problem with the screen. It'll go to the service center I'm afraid. And I have other things to write that's why it's been delayed. So because of the screen problem of WM1A, looks like WM1Z will be the first one to be reviewed.
