pCollins
- Nov 6, 2015
Sorry to hear about that. Yes, mine shipped as promised. Will be here tomorrow...
Amazon UK just shipped mine today. So next week...
FYI to others: WM!Z now £1,975.50
There's two DSD output modes in the settings menu under output settings.
Auto - depending on the receiving decide will switch format (DSD/PCM) to play in
DoP - will output in native DSD but only up to 5.6MHz
Auto is the default setting, so I'm guessing it doesn't detect the Mojo correctly and fell back into outputing PCM. Try using DoP mode.
I have my WM1A over my working table and sometimes, when the unit is stopped, I hear the click of the relay. Anyone has hear this click with the unit in stand by mode?
I hear it not only a few seconds after stop see music. I think the unit activates the relay every XXX hours of minutes. Maybe to prevent it to fix in a position??
Yes it's normal behaviour.
If you don't want to hear the clicking sound simply unplug your headphone from the unit, when there is no headphone connected the relay will not trigger.
you can feed the mojo with WM1A ! which cable do you use ?
The relay is only on balanced or also in SE? thanks, also to @nanaholic wheyou unplug the HPs the amplifer shuts down or stays on?
Balance only - the mechanical relay it only for the balance circuit.
I think I see 2 relays in the main board, so the single end will have a relay too!
For the muting circuit of the balance output there are two “relays” with great presence
Sato Hiroaki [sound design]
It’s a mechanical relay that is opened with magnets when muting sound, and when sound is played it is shut with a click.
Nope, both are for balance. They said so in the interview.
The 1A and dignis case just delivered this morning. I was so surprised because the dignis case didn't come with a screen protector. Anyone know anyplace i can get the screen protector for 1A in the us ?
1a or 1z will work with mojo
Do you have a link for this cable?
