SONY NW-WM1Z / WM1A
Status
Not open for further replies.
Dec 5, 2016 at 3:49 AM Post #5,326 of 45,723
Nice! Is that the reference 8 cable?
How's the difference compare with the stock litz cable?
Yes Reference 8 cable.
Ref 8 sounds more fuller and more power/kicks.
Litz is more laid back and relaxing.
Ref 8 sounds more Live feeling than Litz.
Dec 5, 2016 at 4:31 AM Post #5,327 of 45,723
How is the treble on the 1a, is it bright? Too bright?
Dec 5, 2016 at 4:39 AM Post #5,328 of 45,723
To me even with Andromeda the treble sparkles but with no sibilant.
Dec 5, 2016 at 6:28 AM Post #5,330 of 45,723
Dec 5, 2016 at 8:18 AM Post #5,333 of 45,723
Just got a notice from Sony saying that the Kimber iem cable I reserved will be ready for collection tomorrow. Should I change the mmcx connectors to 2 pin connectors and use them with my Tralucent Plus5 or should I just remove the 4.4mm connector from the cable and have it attached to the uber cable which I currently use my Tralucent Plus5?
Dec 5, 2016 at 8:30 AM Post #5,334 of 45,723
Congrats! Decisions decisions... :)
Dec 5, 2016 at 9:32 AM Post #5,335 of 45,723
  i will be getting mine sometime this week.
i hope that the sony m12sb1 cable will work with the andros
I have my Andromeda with M12SB1 and no problem at all.
Thanks! Just if the reference 8 has a 4.4mm plug option
Dec 5, 2016 at 9:51 AM Post #5,336 of 45,723
Just received my silicone case from taobao, happily surprised...cost me around 12 bucks and the case looks good though very slightly loose on the sides, and it comes with a glass screen protector, which I won't put because I hate applying those things.
Plus it comes with two jack protectors they fit seamlessly in the case.
This will do nicely until I get a Dignis.
Dec 5, 2016 at 10:01 AM Post #5,337 of 45,723
Yep, I saw those on taobao, I was going to hold out till mid 2017 to get them, thats when I will visit japan to get my 1A, apparently the trip to japan got delayed to October, by then or around that time 2A or something else will probably be release, i'll wait and see.
Dec 5, 2016 at 10:49 AM Post #5,339 of 45,723
Nice. How does the m12sb1 sound compared to the litz cable?
Sorry I can't compare coz I replaced the litz cable's 3.5mm plug to 2.5mm trrs for my AK240
just unable to do a fair test as I can't test them with the same source.
Although I feel like the M12SB1 bass are more powerful, vocal more up front and more lively overall
than my litz cable + 240 set up
but I do suspect those difference are due to different sound signature between Sony and AK, not the cable itself.
Status
