mwhals
- Jul 26, 2015
My pocket’s not!
I see you have a WM1Z and Empire Ears Phantom. I hear they don’t have good synergy, but am always interested in other opinions.
My pocket’s not!
I have tried on both. Split my listening time into half with each gear.
when you enable Hi-res Streaming On with DSEE HX. That’s when DSEE HX seems to make some music elements envelop behind your ears. It’s like as if there is a spherical sound field that Sony has programmed in. This surround effect seems be variable depending on source material. It’s as if there’s some kind of system at work that determines which element goes to the front and which element goes to the back of the sound field.
I think these is only the beginning of a new audio system, future firmware should bring about more sonic improvements to this surround mode.
I didn’t expect Sony to have silently added this mode to ZX507 without even mentioning anything about it.
You make me wanting to buy zx507 once again LoL keep on hyping
I am thinking and looking at it in my amazon basket
I sold my IER-M9 a few weeks ago, however I spent yesterday listening to the new firmware with a 64 Audio U12t, which arguably goes one step even further than the M9 in the imaging department.
It sounds sublime with the ZX507.
I must say, the last few firmware updates have really elevated the ZX507. I used to feel that the ZX507 was a great sounding dap but felt the staging capabilities were a big compromise compared to the WM1Z. But, the improvements from the latest firmwares have brought me to the point that my WM1Z is redundant. The 1Z probably still has a slight edge overall, but the gap between the two is now very small imo.
Not sure if Damz87 is using mrwalkman’s firmware or stock firmware for his WM1Z but here’s what he said when he compared his WM1Z against the ZX507 on the latest firmware
Yes, I am using @MrWalkman ‘s firmware on the WM1Z
Did you compare the m9 with kimber kable vs the u12t+ premium silver ?
To my ears both are different enough in sound signature to be able to own both hehe
I’m sure this has been discussed to death but is there a way to determine if an album art image will display or not before I load it up and discover it didn’t work?
I know from past conversations that there’s something about “interlaced” images but I don’t really understand that.
I also heard that jpegs from Amazon work and that the image should have the same name as the folder but I just had an couple albums that I’ve tried twice and the art still won’t show.
Any easy tips I’m missing here or some way I can look at the properties of an image before I try it?
Thanks
JPEGs can be baseline or progressive. The difference is that a partial downloaded baseline JPEG will be shown as a cut image, while the progressive one will be shown whole, but a bit blurry, depending on how much of the image was downloaded. The Walkman OS will only display baseline JPEG files.
You can check if a JPEG is baseline or progressive, here: https://www.imgonline.com.ua/eng/progressive-or-baseline-jpeg.php
If you open a JPEG in Paint, and then you'll save it (use the Save As option), then the resulted JPEG will be guaranteed baseline.
Regarding PNG, this type of image can be interlaced or not. Downloading an interlaced PNG works exactly like a progressive JPEG (blurry image, depending on how much it of it was downloaded), while the non interlaced PNG works like the baseline JPEG image.
I didn't manage to find a similar website to check if a PNG is interlaced or not, but the Walkman OS will only work with the non interlaced PNGs.
Wow... thanks so much for the explanation and the link. Does that explain why some thumbnails in posts only show a partial image when you try to expand them?
I was under the impression that png’s didn’t work at all. Glad to have that cleared up.
I’ll look into a Mac version of the “paint” trick you mentioned.
Gimp for macOS has different menus, but I was able to finally figure it out and the new artwork now shows up, great! With the export command, there is an advanced settings dialog that allows unchecking progressive.
@MrWalkman - thank you for your help!
Check out this post. The user installed GIMP, and when exporting a JPEG you will have an option to choose between progressive or baseline.
What I have is modded 1Z and Romi 1Z with BG caps. For me, most of my iems are warm such as EE phantom, SE5U, CA Andromeda and JVC FX850 just to name few. I hate cold sounding, clinical iems so that’s to that. And I listen to vocals, acoustic, jazz. My mod 1Z is a cross between regular 1A and 1Z. So maybe the comparison is not fair.I see you have a WM1Z and Empire Ears Phantom. I hear they don’t have good synergy, but am always interested in other opinions.
