I always listen in a quiet environment. Never bothered to listen to my Sony + MDR on the go or outside. I listen to my phone on the go when looking for new music for my Walkman. Defo hear much more and enjoy more when quiet or dark or both.
I am now using IER-Z1R with NW-ZX507 and would like to make a step-up towards NWWM1A or NWWM1Z having a home player, portability doesnt matter. I am more into dance, electronic music, I like it bassy. Anyone with recommenedations pls which one to choose? Thanks.
Hello,
I recently purchased the 1A. When I inspect the "full song details" (or something like that) on the device some songs -not all- show "Bit rate: Unknown". Nearly all songs are in Apple Lossless since I use iTunes for archive and tagging purposes. Edit: The bit rate shows fine on my PC in programs like foobar and obv. iTunes.
I couldn't find anything on this matter through Google or the search-bar. Does anybody know what is up with that?
Your problem sounds a bit familiar to me. I had a flac file which had corrupt metadata and showed bitrate unknown but I resaved the tags and got fixed. Could be that some of your songs have corrupted tag section or maybe iTunes codes such info differently than flac ?
It’s about as closed as the Z7M2 for me. Bottom line is that it sounds way different at home now that all the sounds are cut out. Now I’m seeing why these sounds good. Still, the Z7M2 might just be my favorite of all my over ear cans, barely. But best overall goes to the IER-Z1R. Need to listen to the MDR-Z1R more before I make such conclusions. Trying it all on the TA, 1Z, and 1A. But man, looking at the mirror these cans look ridiculously big. But they shine so good on the Sony DAPs
Yeah. I too never remove my cables from my iems or headphones once they’re on. I simply buy another cable if I need to. The less times you remove and re insert the better for the gear in the long run.
For corruption check I use AudioTester (works with mp3 and flac, don't know with Alac, it does not with DSD) for conversions from f.e ape to flac or dsf to flac I use dbpoweramp they have an apple codec suite (AAC and alac, aiff)
