I will try Sandisk Ultra this weekend to see if I can hear anything different.
SONY NW-WM1Z / WM1A
- Thread starter leylandi
- Status
- Not open for further replies.
Sonywalkmanuser
Sorry I am wrong, there exist a 64gb SLC microsd:
https://www.mouser.sg/ProductDetail/Greenliant/GLS93MP064G1-I-BZ801?qs=/ha2pyFadughMYldfvwvPwLTayufDS4Zpa%2B3iehakg6scuU%2B2YYetiLa0K2S62gX
Datasheet looks very impressive:
https://www.mouser.sg/datasheet/2/176/S71486_Factsheet-1826939.pdf
mwhals
- Jul 26, 2015
Look at the price for one 64 GB card! As I said SLC is expensive.
Sonywalkmanuser
Well if you already have an extremely modded WM1 Walkman, the SLC microsd card could be the last piece of the puzzle to ultimate end game sound quality?
jmtocali
- Nov 9, 2009
I'm so happy with my Wm1a, using WM1AZ+. Currently as DAC to a roon bridge in an Android TV Box running Coreelec in Docker. Just now streaming the John Adams' orchestral works recording made by Simon Rattle in Birmingham in Qobuz . It's my Headphone station next to my bed!
Many thanks @MrWalkman
RYCeT
- Jan 23, 2003
To those who use the WM1A with the dock to TA-ZH1ES, how's your battery life? I need to charge mine every other day. I was only using it for 2-3 hours per day.
Use scsitool-nwz-vX.exe https://www.dropbox.com/s/zxfbibs689ma3yq/scsitool-nwz-v25.exe?dl=0Is there any way to see my WM1A's current region?
Command is “scsitool-nwz-v25.exe H: dest_tool get”. Change H: to your Walkman drive in your PC.
Thank you sir!Use scsitool-nwz-vX.exe https://www.dropbox.com/s/zxfbibs689ma3yq/scsitool-nwz-v25.exe?dl=0
Command is “scsitool-nwz-vX.exe H: dest_tool get”. Change H: to your Walkman drive in your PC.
New link: https://www.rockbox.org/wiki/SonyNWDestTool
Tool version is now 26.
Sonywalkmanuser
Guys, this may sound absurd to some here, I don't know what I have been missing out all these years but just only today I have discovered a new sub-genre of music, its called Symphonic Metal. Just want to share this amazing genre of music that is both relaxing and entertaining to listen at the same time.
https://en.m.wikipedia.org/wiki/Symphonic_metal#:~:text=Symphonic metal is a subgenre,orchestra, or just keyboard orchestration.
Recommended DSP for this genre:
Vinyl Processor: Arm Resonance
DC Phase Linearizer: Type A Low
DSEE HX AI ON(if available)
These DSP will accentuate the bass notes to be more hard hitting, Cymbals to sound more crispy and with more airy soundstage.
Also I would think a dynamic/hybrid driver iem, dynamic driver headphone or planar magnetic headphone will sound awesome on this genre. I think the Sony MDR-1AM2 sound signature is perfectly suited to this genre.
Music example:
Music example:
gerelmx1986
FLAC uses vorbis comments NOT ID3, mp4 aac uses iTunes tags
Mp3/DSD use ID3
APE ape tags
Mp3/DSD use ID3
APE ape tags
gerelmx1986
My albums are sorted by composer and all the albums for that composer go there. I have various composers too.
My rags are
Artist - in this one a soloist go there, multiple persons get separated by comma or the name of the ensemble. For the orchestral works I put the name of the orchestra & the conductor.
Album -the name of the album as it is shown in the booklet.
Title- the name of the work , for multiple movements inside same title I use long line or dot ec. String quartet ... : movement A - movement B
Genre - I use the periods f.e Baroqur, romanticism, medieval etc.
Release year the year of release of the album.
Track - usually automated for flac just the current track, for DSD, current track/track total
Disc number- dsme.meyhod as track number for flac just current disc/volume in the series. For DSD current disc/vol / total discs
Fot discs that are Pachlbel often works vol 1 SACD 1... Pachelbel organ works vol. 1 SACD 5, disc would be for SACD 1 1/5, sacd 2 2/5 and so on.. then on pachelbel organ works col. 2 which has two SACD is goes 1/2 and 2/2.
Album Art- baseline jpg scan or from cover from download ar a resolution of 950x950
Composer- the composer, when various in an album, then I use various composers and in title zwischen klammern the composer name e.g Firrworks music, Ouverture (Georg Friderich Habdel) or [Dietrich Buxtehude] Suite BuxWV 243...
FLAC ONLY
DISCTOTAL
TRACKTOTAL
My rags are
FLAC ONLY
DISCTOTAL
TRACKTOTAL
Ok, so If you think that those caps are not making the difference, then I would love to hear what is your take on this?Lol, I already tried 4 x Panasonic Oscons on the balanced out of a 1Z and the FT on a 1A while I was testing different cap combos
MrWalkman's firmware makes it clear that the difference is no longer the firmware.
To me, Hardware is the only explanation.
Anyways, you have installed the best hardware upgrade units, and with the Audionote, so would be great if you could give some impressions.
One positive impression ..Just try CerBerus fw from
@Whitigir. To properly install is a bit tricky. In the end, I love how it sounds on modded 1A. Vocals and Instruments is so realistic and organic. Next level treble textures and lower level details when compared to Solis. Gigantic depth and width. Bass is very large and packed with tons of energy and Sub-bass is better than anything else I try so far. If lower-mid is a bit fuller, This might be the best tune fw so far. Well at least for me LOL!
Two positive impressions...I tried Whitigir Cerberus FW, and GearofWar also created a somewhat flawed Cerberus FW
Ok so we have a few posters who managed to get an improvement, but whitiger tried on original method , then robertP tried on stock, then hamhamhamsta tried on 1z tunnings, and I believe GearofWar tried on some different install procedure, which Mrwalkman proved the file does not load, so something else must be going on, and everyone on this tunnig is all over the place with different base firmware.. I'm using Z tuning btw
Apologies for being so forward or rude by pointing this out.
The primary problem is that has been difficult to load by all, and we don't know what base it should be on.
So I would hope that @whitiger can resolve this by just creating a tunnig to work on the latest firmwares.
Thanks for clearing this up!Both WM1A/Z+ and CHAMELEON firmware’s offer:
- Stock external tuning
- Model switching (from "Settings" > "Device Settings")
- DSEE HX AI (as in DMP-Z1)
- hardware accelerated rendition of the UI (faster menus)
WM1A/Z+ has different base sound, and improved battery life, while CHAMELEON has the stock base sound.
I already clarified this even more in the main post.
Sorry I have to disagree here, about the 1z.Well it's all depends. 1Z still have more amount of bass and thicker sound in lower-mid. 1Z is more about warmth, intimate and emotion type of sound. Some people will like it and some don't. Also it's all depends on your gears.
1A is more about fun, exciting, and realistic type of sound IMHO.
It is definitely NOT more intimate, but instead more immersive.
Maybe that's a description you would agree?
Yes, I can agree that you can be swayed by the more exciting sound of the 1a with the MrWalkman's WM1A/z + firmware), BUT ..
Don't be fooled.
The 1z is the more accurate and realistic player.
It has more depth, more holography, more liquidity and ease of presentation.
It is a different presentation although with similar signature when the 1a has the chameleon 1z firmware.
So to me, the 1a actually is the more intimate, because it has a more forward and lively presentation.
Actually I think neither one is "intimate".
- Oct 14, 2013
@Maxx134 , I understand your desire . However, I am only an enthusiast, and that means I live within my pockets means LOL! Sorry, I can not help any longer
- Status
Total: 27 (members: 1, guests: 26)
