Edit: If you want to post this on other forums, it would be nice to provide a link to the main post, and not
a direct Google Drive link. Thanks!
Hello,
A small update has arrived.
Changes:
- removed the modified Certificate images
Installing the mods will no longer modify the "Certificates" images. This means that we won't need
to use "WM1 Back to Stock" anymore. In order to get back to stock, just make sure you switched
the model to the original one for your device, and then just flash the official stock firmware of your
choice. If you used previous versions of the mods, I uploaded an updater which is made only to
restore the "Certificate" images to the original ones.
- really updated the translations for all languages
It seems that I missed some last time, regarding the "DSEE HX AI" and the "Model Switcher" options.
- the "WM1A to 1Z" mod name has been changed to "CHAMELEON"
As the mod's main purpose is to allow switching your model, without adding any improvements to
the stock sound, and also to make it less confusing when mentioning both mods, the name was
changed.
- the update bar fills up to the end now - really important fix, haha
I also added these mods for the 3.00 and 3.01 firmware versions, for those of you who would like
to try them.
As always, please read the indications in the main post, as well as the
Frequently Asked Questions
section that can be found there.
MAIN POST
Link to firmware in the main post:
CLICK
Thanks!
