nc8000
Meaning no need to change the cables and always keep the 4.4mm say the IER-Z1R to prevent damage from constant swapping?
Yep
It definitely serves a point. If your iems or headphones are terminated with a 4.4mm Jack then you can now listen to it on any 3.5mm port. That’s the purpose of it. Who cares about balanced or unbalanced? The purpose of this adaptor is just for that.
Amazing indeed.Yes. It’s by DD Hifi. They sent me a review unit together with TC35i for iPhone. Fantastic build quality and transparent sound. Used to connect your 4.4mm cables to 3.5mm inputs. Perfectly safe and top notch product. In fact I posted a picture of it a few days ago here.
Yeah, it works, but does the sound improved, more transparent ?Yes it is single ended but the point of this adapter is to allow you to actually be able to use your phones on all sources that only have 3.5. I use one so that I can use both my 4.4 terminated Z1R from my iPad and iPhone
The sound doesn’t improve neither does it get worse. So it’s fully transparent. I tried it on multiple devices and did a review on it.Yeah, it works, but does the sound improved, more transparent ?
Yes indeed. Especially mmcx connectors are prone to malfunction with multiple attach and remove actions. That’s why I never remove cables from my iems.Meaning no need to change the cables and always keep the 4.4mm say the IER-Z1R to prevent damage from constant swapping?
Can someone recommend the adapter? Or adapters to check? Thanks in advance
Absolutely. That’s my interpretation and probably the only correct interpretation of the word “transparent”.Wouldn't transparent be the opposite of snake oil? ie. It makes no difference to sound with or without it.
With DD Hi-Fi offer, thoose are useless if you want my humble opinion.if you want best quality adapters and transparent it will cost you an armmoonaudio.com makes ones of the best. You have plussound less expensive but also quality, I would never buy fiio ibasso or cayin ones sorry
I even tested an pw audio adapter the other day and found it degraded sq...
http://www.plussoundaudio.com/customcables/interconnect.html
I highly rec 8wires adapters as they will retain max sq possible.
https://www.moon-audio.com/dragon-audio-cables/adapter-cables.html
