My first Walkman before the Tape Sports Walkman around 1991. The Watchman!
That’s awesome! Does it still work?
Unfortunately I lost my OG tape Walkman from childhood and my discman from teenage years.
With the battery crapping out should I buy a 507 or another Wm1a?
That's correct, I had to recalibrate my battery to "reset it". Uou discharge it completely until your walkman cannot turn on again (takes some tries) then charge it to 100% (no BatteryCare) uninterrupted - so don't disconnect device from charging source until it reaches FULLWhat is wrong ?
From the user manual
Sony rates the battery at 500 recharge cycles. I’ve had my 1Z for nearly 3 1/2 years and played about 3.500 hours and the battery lasts as long as it did when new. I think gerelmex is near 8.000 hours and started detecting shorter time. He let it fully discharge and then charged it to 100% (dissbled battery saver for that one charge) to recalibrate it and it was back to normal.
@Vitaly2017 @Whitigir if you notice distortions in your flac files, may be placebo or the fact you guys don't know your instruments well.
I do know how the instruments of my music sound like, especially novelty ones like a Tangent Piano, which has many high frequency and low frequency buzzing of its strings when struck, that a novice listener may confuse with distortions or ripping artifacts. Learn to know the sound of your music instruments.
I've learned to distinguish ripping artifacts (skips, statics, scratch, often associated with high speed cd ripping and often with insecure software like MediaGo) from such nuances of instruments.
I must buy a flac download of this CPE BACH the solo keyboard music volume 13, as last two tracks have artifacts (got them pirated from a music blog back in 2009)
is this a trick to refresh battery ?
Dis the same on an iPhone who had battery problems and turned on the phone until I could not turn it on anymore and then charged it uninterrupted to 100% restored the battery issueis this a trick to refresh battery ?
How would one do that exactly? Where would it be sent?
Vinyl and is the Floodland CollectionIs this a vinyl rip? Or is it available to purchase as a download somewhere?
It really is a good album.
TIA
