Hello everyone. It's been a while since I last posted on this site. Brings back memories of what feels like a lifetime ago!
Good to see the site in a great state and it's easier than ever to navigate IMHO
I've a few questions about the WM1A and my TA-ZH1ES ("Tazzy"). I've searched this and other forums though haven't found answers yet...hoping some of you can help
One question, how do I use the WM1A as a digital transport with the Tazzy?
I only want to use the proprietary cable that comes with the tazzy rather than docks or other cable chains.
After selecting the 'WALKMAN' input on the tazzy, what setting do I change if any on the WM1A?
You should consider the dock since it has active electronics, allows the use of a better USB cable and the PC USB port supports higher resolutions than the Walkman port.
Thanks for the answer - If I was to use the supplied cable with the Tazzy - are you saying it should auto detect and allow me to use it as a transport right away?
Yes, just plug the supplied cable to your Walkman and it will automatically configure. It's takes a second or 2 and you will see "Digital" output label in the upper left corner of the screen.
That must mean my cable is a dud since nothing registers.
Do you know where to find an exact replacement of that cable to the tazzy (like for like). I can't seem to find any part number or existence of it online.
I want to use this side input rather than the back USB input which will be used for something else. So I want to avoid using a NWH10+adapter or a dock.
It's for a backup system to my main rig (Laptop - Questyle 12 master - HD800S)
I just ran an informal test yesterday as I’m in the middle of writing a 1Z review. Upon putting a fresh card in it takes a while with 3.01 and 3.02 still not as long as as 3.00. Upon turning the unit off and restarting a 256GB card will be read after already being read previously before turn off in about 35 seconds(firmware 3.02). So it seems the 2nd time is a different process, where with firmware 3.00 it took forever......always....like 3.00 was as being read the first time every time, and it could actually cash while reading the card. 2.0 was faster all around, than 3.00. It also seems like 3.02 and 3.01 are relatively faster overall than the load times of 1.20 and 2.00, but I’ve never actually timed them.
I've had SP2000 copper demo unit borrowed for 2 weeks.
Here's next to my WM1A and DX160
Out of the three the WM1A had the most bass and SP2000 the least, nevertheless it didn't stop him to outclass both of them in every category. The biggest soundstage, the most natural, the most resolving, efortless and liquid, very holographic and three dimensional sound.
I've read in the SP2000 thread that users reported quite dramatic changes in sound with different software versions. I can't comment on that as I tested using only 1.16 version. You can't go back after the update so its hard to verify.
I was suprised from day one it and after 1000 hours im still amazed I have audioned other DAPS staging may be alittle better or expensive ones but 1A sounds very engaging for a 1000us DAP and I havent heard anithing in the 400us ratio that come seven close my creative E5 its very potent but it crashes it my zx100 has 50hs playback but not the same thikness clarity and staging nor bass... and it costed me 600 US so i dont really get what dap in the 400 ratio could be better than 1A
Then you must have... maybe i cannot confirm either very terrible set of headphones... or maybe im just saying maybe you need to schedule an otolaryngologist apointment assap.
