meomap
No.Is there a way to remotely control audio playback of the WMA1/1Z from phone ?
You need to buy the BT remote from Japan for 50 usd.
Yes it has 429 hours
Should Vinly Processor make the sound warmer by rolling of the highs ? I am not sure if I can feel that.
It is quite subtle. Also the more sensitive your iem is, the better you can hear the differences. You can perceive the difference using let’s say CA Andromeda compared to VE Monk $5 earbuds. Probably you couldn’t hear any difference using VE MonkYes it has 429 hours
Dows walkman read .cue files? anyone? thanks
IER-Z1R are sonically great altough because of their rather natural nature they are not the most resolving or detailed.
That’s what I hear too. Bright, huge soundstage and very dynamics.That's the first I've seen the IER-Z1R described in this way. For me, it's the exact opposite. Absolute detail/resolution/separation monsters, but not really perfectly natural due to their somewhat v-shaped signature. *shrug*
V-shape is because of it acoustic-Foam. Do the modifications and it is very different. It can’t be as flat as hd800s but it is a lot better than stockThat's the first I've seen the IER-Z1R described in this way. For me, it's the exact opposite. Absolute detail/resolution/separation monsters, but not really perfectly natural due to their somewhat v-shaped signature. *shrug*
DSEE HX function works for compressed audio sources and PCM audio sources with lossless compression on files that have a sampling frequency of 48 kHz or less.I liked the WM1A's operating system. After trying many Android DAPs (they are all a mess) the Sony OS like a bliss.
DSEE HX upsamples only MP3 ? Or 16/44.1 files as well. And does it improve the things as described ?
I would advise you not to use DSEE with losless audio since prety much i hear the same its very good at some mp3 but i hear slight resolution degrade you will be better served with the surface noise on vinyl procesor function... you can see how DSEE works by turning on your spectrum analizer you will see last bar on and off.. dough i believe losless audio can reach same levels of DSEE if not someone tell me! If you need more bass DSEE may add some more in the subbass region also... but you lose some bass speed too.. so its your choice tell us what you hear!DSEE HX function works for compressed audio sources and PCM audio sources with lossless compression on files that have a sampling frequency of 48 kHz or less.
i Don't use itDSEE HX function works for compressed audio sources and PCM audio sources with lossless compression on files that have a sampling frequency of 48 kHz or less.
