Actually I read that DMP-Z1's DAC is literally AK4997. This is Fiio M11 Pro's DAC and M15 has AK4999 xD
Yes yes it is much more than what DAC chip is being used. But still interesting
Hello guys, new to the forum, hoping you could help me answer a pressing question, I love well build, quality things and I'm normally willing to pay the premium that that entails, that said, a quality build is just half the story for me, as I like to think of everything I buy as lasting forever (I know, I know...), at least knowing that when I part ways with something it's because I went after something better / newer and not because I was forced to. Now on to the question, I'm on the fence of buying a NW-WM1Z, just love the way it looks and the build, when the bettery is good no more, will I be able to use it plugged in at all times? Currently use a Sony TA-ZH1ES for my home rig and use iphone or PC as sources, would be using the 1Z if I get it. Also, have a pair of MDR-Z1R's, everyone talks about IER-Z1R but really cannot afford both, the DAP and IEM, is the pairing with the MDR's a good one?
Thanks Whitigir, just what I was hoping to hear! I'll start saving for the IER as they seem to be well regarded by most if not all owners / reviewers, plus the portability and somewhat discreet nature of them helps a lot with a DAP, as it is, I was mocked in the office with my "lowly" HD-598s and Denon DAC setup, wearing something as big as the MDRs would not go unnoticed :-D, plus I don't like risking them getting damaged or something.
IER-Z1R are sonically great altough because of their rather natural nature they are not the most resolving or detailed. When it comes to comfort I find them uncomfortable for long listening sessions. They are big, bulky, heavy and quite noticible in appearance compared to other iems.
Fiio are always champions of specs on paper but this doesn't translates for the sound. I've reviewed the M11 and it sounds quite hard and technical. It lacks any kind of the warmth or subtlety. Also the screen, superb resolution with extreme PPI but with cold blueish tint.
Nahhh, nothing like that. I didn't realize how tightly the battery was glued to it's housing. I was trying to wedge it out and accidentally ruptured it.
Oh well, time for a new one anyways.
I am going to use 24 gauge solid copper to wire it. Should be easy enough.
And there is no way any portable DAP even touches the DMP-Z1.... Not happening for at least another 10 plus years, if ever.
You don’t have to peel the battery off, it can be done by peeling the tape off. However, peeling the battery off need some heat applied to the copper chassis when the battery is out
Thanks for the input, fit is a concern of mine because it can be heavily dependent on ear shape and size, this is the more true of IEMs than full size headphones, don't know of a place nearby I could try them on nor if I would want to (IEMs going inside the ear and all... you know)
I have the TA/1Z/MDR-Z1R with the Sony Walkman Cradle BCR-NWH10 and AudioQuest Carbon USB cable. I also have the AXIOS Cu balanced for the MDR-Z1R for my home listening. The only thing I would do as a possible upgrade is to find a good pure silver cable. Maybe the DHC Complement4 Silver.
I then I use the 1Z with Campfire Solaris SE, ADV Custom tips and DHC Clone Silver balanced for traveling on the airplane or hotel.
