hamhamhamsta
LolDamn you stole! Bad boy lol
I like it a lot, probably the best sounding IEM to my preference.How are you liking the acoustune? What signature to these have? These are on my Single DD wishlist along with the Dunu Luna & A8000.
Now I understand, I thought it meant internal modifications of the player, in that case I doubt that the cable will consume more batteryI am as referring to the kimber cable for the MDR-Z1R, so this
I think that’s possible. When I’m using PW 1960 4 wire I usually have to increase the volume and put on high gain. That obviously draw more power. Using Radsone ES100 Bluetooth, I could use any wires except PW 1960 cables. ES100 doesn’t have enough power to drive PW cablesI am as referring to the kimber cable for the MDR-Z1R, so this
Same HP, will also test with iem IER-Z1R to see, if i continues to behave like so, then battery is on its last gaspI think that’s possible. When I’m using PW 1960 4 wire I usually have to increase the volume and put on high gain. That obviously draw more power. Using Radsone ES100 Bluetooth, I could use any wires except PW 1960 cables. ES100 doesn’t have enough power to drive PW cables
are you also using the same headphone on both instance? Or it’s headphone vs iem?
I would try to buy a cheap 1A wich screen its ok and replace the 1Z....I recently dropped my WM1Z, and cracked the screen. The device is still functional, but I think the damage will probably get worse over time.
I first called Sony Support at 1-888-222-7669. They told me that since it was physical damage, it would be an out of warranty repair (as I was expecting), and told me to follow up with their authorized 3rd-party repair service, United Audio Repair.
UAR subsequently told me that they do not carry parts on the WM1Z - and according to my CSR's records, haven't worked on a WM1Z since 2018 - and told me to follow back up with Sony.
Upon second call, Sony told me that they can't do anything, as they don't even stock the part for the screen, because it is "discontinued". The CSR then suggested I take it to Best Buy/Geek Squad for repair.
I first asked how a part could be discontinued, when the player itself is still being sold as new. I then asked what Best Buy would be able to do, if they cannot get ahold of any screens, since they are, according to her, discontinued. She had no answer and so that call went nowhere.
Anyone have advice on getting my screen repaired?
Haha that was me at 0:51
I was nervous lol being filmed live on tv!
I imagined a tiger would come out but it didn't happen
Both of you know that the cat is the teacher to the tiger right ?
