SONY NW-WM1Z / WM1A
Status
Not open for further replies.
Jan 21, 2019 at 1:27 PM Post #26,791 of 45,723
There is no program, you use whatever programs you already have and select the Sony as your output device in sound settings in Windows
Right, he is saying you use whatever music software you have, like -Foobar2000.
Jan 21, 2019 at 1:29 PM Post #26,792 of 45,723
thanx for the help ,so let's recap
1) i have 3.01 on my wm1a
2) i need to donwload/install on my pc this
https://www.sony.co.id/en/electronics/support/downloads/00014879
3) then plug my wm1a in usb cable on my pc and activate usb dac
correct ?
You turn on the DAC function first before hooking the 1A to the computer. I don’t use this but kinda know how to do it. I didn’t realize in your earlier post you already had 3.01 working fine in your 1A, but just needed Windows drivers.
Did you download the Windows drivers?
Jan 21, 2019 at 1:32 PM Post #26,793 of 45,723
windows sony drivers downloaded/installed
so i open the usb dac option on wm1a , and then hook the wm1a on my pc via the usb cable ?
Jan 21, 2019 at 1:34 PM Post #26,794 of 45,723
Jan 21, 2019 at 1:35 PM Post #26,795 of 45,723
Yes.
Jan 21, 2019 at 1:36 PM Post #26,797 of 45,723
ok , i get a ''installing device driver software'' icon , this is the sony driver i downloaded from your link i guess
after it's done , i will press pay on foobar 2000 and i should get sound on my wm1a ?
Jan 21, 2019 at 1:38 PM Post #26,798 of 45,723
You may have to select the Sony as the output device in Windows. I use Apple as my PC for this. Lol
Jan 21, 2019 at 1:39 PM Post #26,799 of 45,723
You first need to select the Sony as your output device in Windows sound setting
Jan 21, 2019 at 1:40 PM Post #26,800 of 45,723
driver installed , so how do i slect sony as output device ?
sorry for the nagging , complete tech dork here i guess
Jan 21, 2019 at 1:41 PM Post #26,801 of 45,723
Jan 21, 2019 at 1:43 PM Post #26,802 of 45,723
nvm guys , i improvised and i get sound from my pc to my wm1a
VICTORY :L3000::L3000::L3000::L3000::L3000:
THANX FOR ALL THE HELP YOU ARE THE BEST :ksc75smile::ksc75smile::ksc75smile::beerchug::beerchug::beerchug::beerchug:
Jan 21, 2019 at 1:46 PM Post #26,803 of 45,723
one last question , i get a PCM 48khz file read on my wm1a even though i am playing some 24/96 files from my pc
does sony down-convert files from 96 to 48 khz ?
Jan 21, 2019 at 1:47 PM Post #26,804 of 45,723
Jan 21, 2019 at 1:49 PM Post #26,805 of 45,723
one last question , i get a PCM 48khz read even though i am playing some 24/96 files
does sony down-convert files ?
Someone here will help you, I don’t use the 1A as a DAC normally.
Status
