Yes, it seems the DAC feature is not working with my MacBook Air? It sees the Walkman but flashes off. Only a driver for Windows now, mabe later Apple will get one??
Exactly as Music Center takes and tries to arrange all your music. Just go and download the updater. Load it off your browser. I updated both players in under 10 minutes.
Ohh.. the new FW has made the WM1Z less warm, less bassy, wider soundstage. The Z1R + WM1Z combo sounds more palatable now. First impressions, the WM1Z & the TA-ZH1ES sounds closer now
I have not tried the Z1R yet, but the update changes the soundstage the most with big soundstage IEMs. The soundstage must get bigger with the Z1R? The bass must be tighter now with the Z1R/1Z combo and more detailed.
Did anyone noticed random restarts on the 3.0 firmware. I've had two already in the last 24 hours and I haven't had any in the past year of owning wm1a.
Did anyone noticed random restarts on the 3.0 firmware. I've go two already in the last 24 hours and I haven't had any in the past year of owning wm1a.
What's your iPhone? I tried on my 4s (yeah, no new iPhone yet), it needed the camera kit and yes, charge this device from the source to work. but it did output audio.
i think wm1a with 3.0 sounds leaner compared to 2.0
not sure if this is good or bad , need to spend some more time with the new FW as at some albums i feel the sound as being sonewhat more 'metallic' , like going from Zeus XR on a copper cable to a silver one
gonna try the vinyl thing setting, maybe this will make the sound more warm/balanced
I can't install it via my Mac running Sierra. The update crashes repeatedly. The instructions say to connect the Sony, then download, and run the updater. The on-screen instructions say to remove the Sony, then reconnect it. As soon as I do, the updater crashes. If I don't remove it, the updater crashes.
Standard - thicker notes acros all frequencies with lower clarity and softer attack compared to Direct Mode
Arm resonance - a little thinner and with added crosstalk so it sounds less focused.
Turntable - resonance - same as arm resonance but more subtle effect - more focused but still thinner than Standard
Surface Noice - notes as thick as Standard but less and softer upper midrange and highs.
Direct Mode - most nuanced, best clarity and transparency, best attack
