NaiveSound
- Nov 8, 2015
https://www.amazon.co.jp/WALKMAN-NW-WM1シリーズ用-本革レザー-キャメル-CP-NWWM1LC1/dp/B01N0XRRYI
Cheers!
Exact case I have.
But if your in usayou can't order?
Cheers!
Exact case I have.
You have to use a brokering service like Buyee
Cheers!
Probably in my next life hahahahaha. I have zero skills and patience for this. But thank you.
And it looks very well done.
Ouch $145 for usb c, it might not work as those WM port doesn't have chip in it to transfer digital, the big one doeshttp://www.chinaglobalmall.com/products/560753357040
Don't know why this site is in hebrew... but here you go..
Nope that wont work neither, as that wm port is for charging only, I had it before and it doesn't work, only the combo below work, for a total of under $50
I guess these 2 in combination then
Thank you, lots of parts, a link possibleNope that wont work neither, as that wm port is for charging only, I had it before and it doesn't work, only the combo below work, for a total of under $50
There only 2 part you need and both can be bought on AmazonThank you, lots of parts, a link possible
which cable would i need to use my wm1a as DAC with my Dell Laptop (Foobar app) ?
That is correct, as this cable have the chip in it and the chip capability is for digital hi res transfer, as for the normal wm port that doesn't have the chip, it doesn't have the capability to transfer digital hi res, it can only do analog, so by converting the female end of the cable to usb c or micro usb is the best way to go, same way go with chord hugo and mojo, this is the only cable that will workActually when the DAC function is enabled, this cable WMC-NWH10 is the recommended cable adapter. Sony stores in Japan actually market this as the most High-Res option (When connecting to audiophile USB) to passing signal out to an AMP, and so it will work the same in reverse for DAC function.
