San Man
- Dec 21, 2015
Get it from Razordog. It's grey market, but you'll save a lot of money vs BB, or check the classifieds for a new/used one.
Questions: if I buy one of these in Japan, should I do the firmware update using the Japanese file from sony.jp? Should I do the firmware first (assuming it needs it) before Rockbox to English? Or if I do the region change w/ Rockbox first, can I then use the firmware update for that region? Also, is it ok to just jump right to the 2.0 firmware regardless of the firmware version out of the box?
There is only one fw for all regions, you can do rocbox before or after and you can go straight to 2.0
So I can just pull the file off the US sony site and follow the English instructions? I can actually read Japanese on about a 1st grade level, but yeah that simplifies things considerably lol. Thanks.
I belive so yes but as I don’t have a Japan unit I have not actually tried it
We have a search funktion here.I'm sure there are a few here with Japan-bought WM1's who will confirm or elaborate. Anyone? Bueller?
I owned my LPG for the last 2 to 3 years still sounds great. In my opinion no comparison. I'm looking for something better than the LPG in SQ. Right now I'm having my eyes on WM1Z as an upgrade. Is it like a WOW difference? What do you guys think?
I bought a Japanese unit. And I confirm that the firmware update downloaded from US site worked without any problem. I converted the country code after that. It also worked no problem.I'm sure there are a few here with Japan-bought WM1's who will confirm or elaborate. Anyone? Bueller?
