Still it is way too expensive to buy bought but looks like i will
Only James Bond lives twice....
hmm sony XBA-Z5 (499 on accessoryJack) but doesn't has a 4.4mm out of the box, it has a dual 3,5mm balanced atndardAny good advice for a first IEM for my WM1a on balanced? Let's say under 500 bucks.
I’m sure it’s not 2K better, I just took the step right away so not to risk buyers remorse and speculation
If you can find in sale forum, ASG 2.5. 1A will tighten the bass and provide the much needed treble. But you will need to eq and use all other enhancements to sound best. 1A/ 1Z does eq very well.Any good advice for a first IEM for my WM1a on balanced? Let's say under 500 bucks.
Do you have any idea when Sony will release the next great DAPs like these?
I believe you're right.A good bet is for the 40 years jubilee of the Walkman in 2019
quality of your music files... what file format are you suing? i use FLAC and DSD no lossy mp3 or mp4 AAC hereOk, so I'm still waiting on a 4.4 adapter to try out the balanced on my 1Z. In the meantime, I have about 50 hours on the SE jack, and it still sounds like there is no channel separation, let alone any width to the soundstage. I've played songs where I know there are definitive left/right instrument placements, and everything sounds like it's coming direct center. Does burn in really make that much impact on this, or should I be looking at other possible reasons? Thanks for the advice!
Burn in makes quite a difference, in my experience. When not using it, I leave it plugged into power, and playing continuously, when it was new and I wanted to speed up the time it takes. Sony recommends 200 hrs. You can try following Sony's recommendation, as it does not take that long, and you can use it along the way, and decide whether it makes a difference or not.Ok, so I'm still waiting on a 4.4 adapter to try out the balanced on my 1Z. In the meantime, I have about 50 hours on the SE jack, and it still sounds like there is no channel separation, let alone any width to the soundstage. I've played songs where I know there are definitive left/right instrument placements, and everything sounds like it's coming direct center. Does burn in really make that much impact on this, or should I be looking at other possible reasons? Thanks for the advice!
