Awesome thread! Wish I had known about your thread. I had to figure your it out by trial and error. Love that you have images to support each step. That is very helpful.
Is the new tip feel grippy or is it a smooth silicon? I had maybe 20 hours of usage of my IE800 as it simply doesnt stay put in my ear. Thanks in advance and love your reviews.
Included silicone tips feel silky smooth. I think the ear anatomy and how oily your skin or how much wax you have can all play contributing factors From my personal experience, I have used IE800S with silicone tips (the largest one) for many hours in the last few weeks, and found them to be very secure, super comfortable, and providing great seal and isolation. I was seriously worried about sound leakage and passive isolation due to those large vents in the back. Found no problem at all, even after extended listening session. Also, after multiple uses with pulling them out of my ears, the plastic nozzle inside eartips always stayed securely latched.
Btw, US Senns will lend me IE800 for a few days so I can compare the sound; looking forward to that.
The only way to find out is to compare it side-by-side...
and back on topic - the soundstage expansion is unreal driving IE800S with WM1Z from balanced. Also, such a pleasure using right angled 4.4mm connector without any adapters.
In the USA, you can order the 3 Sony plugs online at www.encompassparts.com (one of the two Sony parts distributors) or call 1.800.432.8542, using part #'s 4-574-056-01 ($2.82),4-591-289-0 ($2.34) & 4-591-290-01 ($2.25). They're not in stock, but I placed an order this morning.
