I am happy to share my new finding ...
This is a potential a good news to 1Z owners who find FW2.0 is too "clinical" and prefer to use back FW1.20 for the more musical sound signature.
I find the below sound setting and steps in FW2.0, will provide a relative attractive musical signature, may be achieve 80% of the FW1.20 musical sound + 70% of the FW2.0 sound characteristic ... I find no noticeable lost in resolution, personally I find it musical enough with good sound quality, no longer has the urge to use back FW1.20.
Pls you all try these below sound setting steps and let us know how do you find , especially those who has the Sony headphone Z1R ....
Step 1 : Go to Direct Source - off , go the manual sound setting.
Step 2 : Select Equalizer (not Tone Control), make sure the adjust setting is all zero - flat (completely no setting for all the frequency spectrum). Never select Tone Control display . . it may degrade the sound resolution even the setting for the base, mid and treble is all at zero scale.
Step 3 : Go to next DSEE-HX screen, click "ON".
Step 4 : Go to next DC Phase Linearlizer, click "ON" and I suggest select Type A -low (other selection may give slightly different base tone).
Step 5: Safe the setting, and make sure follow by reset the player (this is important step to ensure player use the new stepping with the clean setup. In fact every time if you make selection from Direct on to Direct off and vice-verse, you need to reset the player ... .. you will find the sound is not the same with and without reseting the player.
Pls try and share what you think ...
The above mention “Reset” , means to power off and then power on .
