- Oct 14, 2013
Well, prepare to get used to it . I am sorry, every hobby cost money....hell, even if you are into girlThank you very much! You confirmed my thoughts. My wallet cries....
Isn’t that true ? Be glad though, the only time you can afford your hobby, that is the time marked down as your grown up timeOr boys
That's what I've told people, on the wm1a/z balanced output brings out the best in the music played. Though I feel with the 1a, balanced is significantly better than single and on the 1z just slightly so. Probably a sign of the price difference.
This is exactly what I experienced
Balanced is indeed better than the se on the wm1a but only marginally
Today I just experienced something totally bizarre, and now I kinda know why one of my microSD was bricked. LeXa 128Gb was bricked.
So what did I do ? I had this microSD inside my Android Player Dx200, the LeXa before I had it in the HTC10 smartphone. Uncounted from within Android and was prompted that it was safe to eject. I did just that, took it out, and pushed it into Wm1Z.
The next thing happened, my Memory card Music folder was wiped clean on my Sony Audiophile 64Gb. I thought it would be bricked, but i could still write files on it *sigh* such a relieve. On my LeXa 128Gb before, it kept hanging in creating database.....the next thing I know, it was not readable by any Android Devices, or Walkman, but only Readable by Computer Windows 10. It was unwrite-able and or formatable....totally bricked, but somehow I could still copy files from it if I used windows 10.
I don’t know anything about programming, and the behavior leaves me speechless....
Burn the balanced. It's not a slight improvement over single.
I think you can erase the card via partitioning tool (partition wizard) and re partition it. It might fix your card as it works on a deeper level than windows basic formatting system.
Strange. Try to copy files to back up and reformat memory card this way - insert into Android device, connect to computer and start formating from computer - if it will be seen by computer.
I tried it and it didn’t work. It always prompts that it is protected
I did copy the files out of it and stored into a memory usb stick instead
Now I am trying to get my library into this Sony microSD card again. It was Bizarre, and bothersome
Really looks awesome, can you take pictures of every angle with the walkman in the case?
Does the balance output on the 1A has the same power as the 1Z (230 my)?
