DO NOT USE A 9V, 15V, etc charger. These are the wrong voltages, and may fry the Sony. The charger for the Sony (and most modern devices), is a 5V charger, and I am sure that this is in the Sony specs. Do not confuse the higher voltages that you see mentioned in the charger specs that are related to either QC (Qualcomm Quick Charge) or PD (Power Delivery) standards implemented on the charger.
- QC and PD are both functions that need to be built into the charger, and the device being charged. These will allow the charger and the device being charged, to handshake with each other, and negotiate the voltage/current to be used for charging. A modern 5V charger will start off at 5V, and then handshake with the device being charged to see if it has either PD or QC. If the device answers either query, then the Voltage will be set at both ends, and the charger will switch to either QC or PD and continue charging. Higher voltages are used for higher current, as this is more efficient, and creates less heat. As the current requirement drops, the voltage will be adjusted lower, automatically.
Recommendations:
- Only use a 5V charger, that has QC and/or PD capability. Most modern chargers will have both. The device being charged, and the charger, will negotiate the voltage to be used, or it will default to 5V
- Use a high current charger. The higher current charger is engineered to higher standards, will have more current reserve, and will run cooler. GaN chargers are preferable, as they are more efficient, and run cooler. The current will automatically be adjusted by the charger, as the device only gets as much current as it's charge circuit asks for. A high current charger will not overload the device being charged, as a charger does not "push" current to the device. The device being charged "pulls" whatever current it needs from the charger. The charger functions as a reservoir, so you want a good quality, high current reservoir. A 65W or higher charger is good for general usage.
- a PC is mentioned for charging, as that is readily available, in case the user does not have any other charger. A PC USB 2.0 port will limit the current to 0.5 Amp, so will take a long time to charge. Plus if the PC goes to sleep, may shut off the charging. The PC is an alternative option, and is not the best option.
In summary, the most convenient/best charger for the Sony, and other devices, is a high current (65W or higher) multiple port charger. As the PD standard is optimized for USB C, get chargers with USB C output, QC & PD capable.
A low current charger can overheat and fail, when trying to output current that they are not capable of, and generate voltages that can damage the device being charged, so I stay away from low current chargers. All modern chargers are inverter devices, which operate at very high voltages, so have the capability to output damaging voltages if they fail. It is for this reason that Apple did a recall, and offered to replace non Apple chargers with Apple chargers.
Get cables that are USB C, and PD rated just to be sure, as none PD rated cables may, or may not be able to charge using the PD standard.
And it is very important to pay more, and get high quality chargers. DO NOT GET CHEAP, LOW QUALITY CHARGERS. This would be a false economy if they fry the device being charged.
