Only issue is that they are sold out in Japan as well...
SONY NW-WM1Z M2 / WM1A M2
chaturanga
- Nov 26, 2016
no limits in the original, japanese version.
if you are located in europe... i would order one as well
Thank you for quick answer, so do you know what is the output power when it's not limited?
I am in Turkey, and one of my friend's wife is in Japan now. As I am checking only used ones are available to buy right now.
chaturanga
- Nov 26, 2016
There are listings for used ones but I am not sure if should I take this risk..
chaturanga
- Nov 26, 2016
https://www.sony-asia.com/electronics/walkman/nw-wm1am2/specifications
On this page it says 250mW + 250mW what is that plus here And isn't it very weak output power for hard driven headphones? Can I drive HD600 with these numbers for example?
Used things, at least from Japan, are worth the bargain they ask for imo. Take the plunge.There are listings for used ones but I am not sure if should I take this risk..
It drives my 800S at 100/120 volume comfortably..https://www.sony-asia.com/electronics/walkman/nw-wm1am2/specifications
I actually just tried this pairing on a lark and wasn't expecting much.. found myself getting pleasantly surprised and am now trying my usual albums.. Dynamic Normaliser pushes volume up a tad more. The WM1ZM2 isn't just pushing volume but it doing it with authority.. I'm shook.. sounds as good if not better than out of 3Max...!
DarkEchoes
Which USB DAC are you using? I have a Qudelix 5K and to use it with the Sony Music app I need to set it explicitly to 44.1KHz, 48KHz, 96KHz, etc. If I set it to the auto option that automatically chooses 44.1/48/88.2/96KHz then it won't work at all. If I use Tidal or Apple Music then I can set it to the auto option and it will play as expected. This behavior is not what I experienced on my A105, I could just set it to auto and everything would be fine.Edit- I could not use usb dac on my unit. (No sound) does anyone else face this problem?
I was taking about wm1am2, I figured that out.Which USB DAC are you using? I have a Qudelix 5K and to use it with the Sony Music app I need to set it explicitly to 44.1KHz, 48KHz, 96KHz, etc. If I set it to the auto option that automatically chooses 44.1/48/88.2/96KHz then it won't work at all. If I use Tidal or Apple Music then I can set it to the auto option and it will play as expected. This behavior is not what I experienced on my A105, I could just set it to auto and everything would be fine.
Change quality here first if you use windows.
Does anyone have a direct comparison of nw-wm1am2 vs nw-wm1zm2?
How do the sonics differ? Price difference is steep...
The usual... the 1Z2 isn't twice as good... I only got it because the 1A2 will only come in late August here and I didn't want to wait anymore. Up to individual's finances~Does anyone have a direct comparison of nw-wm1am2 vs nw-wm1zm2?
Toronto699
There is no volume Cap on the Japan Version , and you can select English when u set up the walkman , Noteworthy Audio near Toronto told me the new walkmans are backed ordered till the second Quarter of 2023 , if you can get one from Japan Take It ASAP ,Can I ask is there any volume limit in Japanese ones? I am thinking to buy it from Japan. (one of my friends is there now)
https://www.noteworthyaudio.com/
Update "just heard back From Sony . No known ETA. That’s not good!" Noteworthy Audio
- Mar 21, 2007
First PS5's...now this. Debating whether to cancel my order.
buzzlulu
- Nov 27, 2003
I think I will stop following this thread and dust off my first generation 1Z
Silverlinings
C'mon....no way. This better not be true.There is no volume Cap on the Japan Version , and you can select English when u set up the walkman , Noteworthy Audio near Toronto told me the new walkmans are backed ordered till the second Quarter of 2023 , if you can get one from Japan Take It ASAP ,
Toronto699
Bay Bloor Radio , G&G Electronics , Fillion Electronique , Noteworthy Audio , ExcellentPhoto , Sony Canada all Said "No known ETA" By Sony , Sony Canada web delivery Service "Gentec" Also Said "No Known ETA"C'mon....no way. This better not be true.
All Any Of Them Had This To offer Pre Order and Wait
https://www.thesonyshop.ca/products/nwwm1am2
