Sonywalkmanuser
https://www.torachanblog.com/2022/04/sony-nw-wm1am2chord-mojo2.html
https://www.torachanblog.com/2022/04/sony-nw-wm1am2ibasso-dx300.html
This time as well, the earphones are connected to F Audio Dark Sky with the attached cable using the included 3.5mm adapter for single-ended connection, and Mojo2 is connected to the same SONY A105 via USB, and the W. Music app is playing the 24/96 download sound source. increase.
What surprised me when I listened to it again this time was the good single-ended sound quality of the WM1AM2. From the conclusion, I felt that there was a part that exceeded the sound of Mojo 2 rather than inferior to it at all.
It is the number of sounds and the high scale that I felt even when connecting in a balanced manner. I thought that Mojo2 also had a rich number of sounds and made me hear a sense of scale, but the WM1AM2 goes even further. Therefore, even if you are listening to the same song, WM1AM2 is more powerful and you can listen comfortably. And the closeness of vocals. There is power that is not buried in the thickness of the sound. I think that this area is also raising the level of comfort.
If you switch to Mojo2, it sounds a little lighter or cleaner. I like this area, but I think both are at a high level in terms of sound quality.
However, I wish WM1AM2 had a little more output. The TINHIFI P2 Plus I use isn't enough for a single end. You may feel that way even more with headphones. With Mojo 2, you can rest assured that there is no worry about the output.
However, this time I found that the sound quality of WM1AM2 is at a fairly high level with balance and single end. I think that even the high middle DAP in the middle of 100,000 units is top class. Isn't it one of the convincing ones that it is popular?
It will be the impression I heard in this state.
First of all, the current WM1AM2, but I have no impression that the sound is light. Of course, it depends on the song, but I think it's finished in a calm sound.
This is comparable to the DX300. If there is a difference, the DX300 has a stronger direct feeling, and the WM1AM2 feels a little more mature.
However, there is a big difference in the spread of the sound and the impression is different.
The DX300 spreads well in the horizontal direction, but less in the vertical direction. On the other hand, the WM1AM2 spreads well in the vertical direction, making it easier to feel the three-dimensional effect and increasing the immersive feeling.
When I listen to it at a glance, I feel that the DX300 is more familiar to my ears and has higher sound quality, but when I listen carefully in a calm environment, I notice the goodness of the scaled sound of the WM1AM2.
I think the WM1AM2 is the one who can enjoy the thrilling presence and power.
After all it turned out that it is the best Walkman who was particular about sound quality.
Therefore, the conclusion was completely opposite to the impression of the audition. Even though the sound source and environment were limited for a short time, I thought again that the impression of the over-the-counter audition was not always correct.
