psikey
- Jul 15, 2008
You could be, if you don't know that better exists.
Same as above, but I could personally live with 256 kbps AAC if for some reason nothing else would be available anymore.
I'm not personally into this, so I can't comment. I just use a microSD card to have more available storage.
Well, of course that a smartphone cannot play at the same quality as the $3700 Walkman player.
If "better" can be achieved, then why not?
If you can get better sound quality by using a certain microSD card (aka if you can perceive differences, etc.), then it could be something to use one. Otherwise, if 256 GB is enough for your music, then there's no point, right?
What I'm asking is the noise, or whatever it is, should be at its best (lowest) just using internal storage with no mSD. My small HD music collection and streaming storage should actually fit in 200GB even though I do have a 512GB EVO mSD.
The UK sourced Z may be coming now as it seems to have been an "anti-fraud" payment delay that initially cancelled the order. If it doesn't mysteriously get cancelled again its meant to be coming Thu-Sat so I can hopefully give feedback about any EU/UK volume cap and missing high gain. No promises
