My A25's 3.5mm port has become a bit loose because of drops or strain inside skinny tight jeans while walking. I know it must be a simple job to tighten the port by opening the back-lid but can one tell me how to do it?
SONY NW-A20 SERIES
- Thread starter leylandi
gerelmx1986
Hi there, i will be getting one of these soon. Does it support the 400GB card? I willbe using it for commute, so really dont care for larger cards
gerelmx1986
gerelmx1986
It has a very nice sound for sucg a small device.
sounds great with the MDR-Z1R, IER-Z1R and the venerable koss porta pro.
contrary to what @Raketen says of the IER-M9, the IER-M7 soesnt pair that well with the A25, perhqps dur to that M7 lacks the extra supertweeter of the M9.
bass on the A25 punches well and rumbles fair (porta pro IEr-Z1R)ho ever with MDR-Z1R the bass is light, not being driveb as well as the WM1A
Mids i did mot motice so much diff with any of the HP and IEMs.
highs with Z1R (both) have wome nice extension and airiness, though not the same texture as wm1A. With porta pro and M7 there is a perceived lack of extension this gibing impression of less detail retrieval.
imaging amd stage is quite good for such a tiny device, not as holographic as wm1a but still big stage.
Ui is a bit laggy with 950x950 covers.
It does not support external cover art, not even file named same as directory of musics.
SD scan super fast, indexes 28k songs in 22 minutes.
supports 1TB cards
it does not do DSD, in fact it ignores .dsf or .dff extensions
I found the golume to be too brusque woth changes. Vol. 12 of 30 was already loud
poo unit i got from @WilcoRoger it seems it had a very eough life and beimg beaten lol. To my eyes, it looked pristine (visual acuity of 5%) until i used a magnifiying glass... it is mot that bad for my kaputte eyes lol
supports 1TB cards
Raketen
- Apr 5, 2010
I use A17, though probably A25 is similar. A17 does seem a bit warm compared to A55- You could be right if M9 is brighter than M7, that might be helping it sound better. It's probably not full performance but I think it sounds very pleasant, and has full bass other weak sources like my phone lack with M9.
I find A17 a little underpowered for porta pro, though it sounds OK.
gerelmx1986
Yes even WM1A SE high gain cannot deive porta pro fullyI use A17, though probably A25 is similar. A17 does seem a bit warm compared to A55- You could be right if M9 is brighter than M7, that might be helping it sound better. It's probably not full performance but I think it sounds very pleasant, and has full bass other weak sources like my phone lack with M9.
gerelmx1986
With the USB OTG sony cable, could you listen to DSD files? Or these little players like my case, ignores the dff and dsf extension entirely?If we use the USB-OTG cable of Sony (WMC-NWH10) to connect an external DAC (Oppo-HA2),
we can still listen to FM Radio of Sony through the DAC's headphone out?
gerelmx1986
gerelmx1986
I gave my A25 a spin the last two weeks. Started with train ride to berlin, i played some 16/44 files and two albums in 24/88. Then during the time i played discs 18-33 drom haydn symphonies (16/44 flac). Battery dropped to last bar and that was sufficient to take ride back home 4h 30min . Arrived home and battery was blinking so decided to perform a recalibration.
sounds very nice for such a tiny device (sony M7 IEM) performance may not be top notch but anyways very very good.
I can tell you , better than ibasso DX300 which i tewted on saturday before coming home last week. IMO A25 us cleaner than bx300. The ibasso had an off signature to me, too warm and laid back that for me it presented treble roll off.
symo
- Jun 15, 2016
Hi gerelmx1986, you mentioned that you recalibrated the battery, how did you do that.
Also, what audio enhancements and eq did you enable.
Thanks
Thanks
gerelmx1986
I have mine with no EQ.Hi gerelmx1986, you mentioned that you recalibrated the battery, how did you do that.
Thanks
as for battery recalibration do this
- Run the walkman until it says low battery, please charge.
- Keeep turning it on until tou cannot longer turn it on. It may take some time
- Plug it and leave to charge ininterrupted until nattery icon says FULL
symo
- Jun 15, 2016
Thank you!
BTW, do you use clear audio or other enhancements?
gerelmx1986
No. I foundthem to sound artificialThank you!
symo
- Jun 15, 2016
gerelmx1986, Thanks again for your reply.
gerelmx1986
I use mine woth a 400GB card, more than sufficient IMO.
