xeizo
I used the MDR-CD770 as my main headphone for many many years, the Z7M2 is like a really natural and more luxurious direct successor to CD770
Theres alot more done in the inside of the earcups.It turns out that I actually have a modded Z7M2 originally from @dougms3 The earpads are third-party perforated pads and it is partially fo.q modded (the previous owner removed the tape over the earcups themselves, but left the ones over the headband arms). The inner earpad retaining screw has been removed, so swapping earpads is simple. I'll be getting the original earpads soon, so I'll compare the two earpads and see which one I like better.
You should demo the stock z7m2, you will be quite disappointed.Honestly, I'm not sure what to think about my Z7 now. The seller did not mention that it was a modded Z7M2, so I didn't expect to buy a modded pair. It's like stumbling upon some rare heirloom item, but my impressions will not reflect the regular, stock Z7M2. The fo.q mods still seem a bit snake-oily to me, but at minimum it should add more damping to the inside of the earcup, so it makes sense that it reduces boominess and improves control in the bass. Sony made a big deal about the washi paper inside the earcup on the Z1R acting as damping material, so the tape should act in a similar fashion. Ultimately, I like what I'm hearing from this modded headphone and it's probably a bit closer to the Z1R with the improved damping, but I don't know if I would have liked the stock Z7, or if my impressions would be representative of the Z7M2 in general. I'll do more comparisons once I get the stock earpads.
Thanks for going into detail on the mods. I don't argue against the final result of all of these mods and I stand by the impressions I made a few posts ago. Part of my apprehension is that on another forum, some users were interested in reading my impressions on the Z7M2, and since I have a one-of-a-kind item on my hands now, I don't want to mislead anyone into thinking that this improved sound is the same sound they'll get if they buy a Z7M2 straight from Sony.There were a couple times where I returned it to stock and trust me, the mods are a huge improvement. If you want, you can return it to stock fairly easily, except for the solder.
The mod is originally from cdacosta and I just built upon it.
If you do get a chance to demo the stock version, I'd love to hear your comparison. I think the biggest difference between the two is the modded version has much more control, detail, texture to the bass. Its also less peaky than stock in the treble yet more detailed, nuanced and resolving, mids are also a bit more prominent.Thanks for going into detail on the mods. I don't argue against the final result of all of these mods and I stand by the impressions I made a few posts ago. Part of my apprehension is that on another forum, some users were interested in reading my impressions on the Z7M2, and since I have a one-of-a-kind item on my hands now, I don't want to mislead anyone into thinking that this improved sound is the same sound they'll get if they buy a Z7M2 straight from Sony.
I agree with the improvement in the top end with the stock pads. They did have better nuanced treble and less bass than the aftermarket pads.The original earpads arrived today. It took a bit of finagling to get them on, as the lip of fabric around the earpad is longer than on the aftermarket ones, but I got them mounted. From my initial listening impressions, I think I like them more than the aftermarket ones. Vocal timbre isn't as messed up to my ears, and when I ran a sine sweep, the aftermarket ones produced a dip around 2.7 KHz that affected vocals while that dip doesn't appear with the stock pads. Bass is reduced, but still full and punchy, and there were times when I thought the aftermarket pads over-emphasized the bass. The soundstage and vocal placement aren't as wide and deep as with the aftermarket pads, but the qualities aren't gone, just reduced. And finally, it seems that there is more treble. Upper treble and air is the thing that I was missing with the aftermarket pads, and now there's more definition and body to hi-hats and other high-hitting instruments. Importantly, to me it doesn't seem like the increase in treble has diminished the musicality that I first noticed when I listened with the aftermarket pads. There's a bit more spice to the sound, but it doesn't overtake the fundamentals and lower harmonics.
Perhaps some of this is just the novelty of hearing the different pads, but as someone who likes having "air" and "shimmer" in the sound, I prefer the stock pads. But I'm glad I have the aftermarket ones to be able to switch to that darker, wider, and bassier sound when I feel like it. Oh and comfort-wise, I don't find it to that that much worse than the aftermarket ones. The foam in the stock pads is firmer, maybe due to lack of use, but my ears still don't touch the driver despite the reduced thickness.
There's a cold snap in the US northeast right now, so the added warmth from the stock pads is actually welcome, but that will likely change in the summer. Perhaps the aftermarket pads will be summer pads and the stock ones will be winter pads, lol. Changing them with the season, like snow tires.I didn't have any problem with the stock earpads except that they were so hot.
I have large ears and the material its made of, caused my ears to get extremely hot, heat bite if you will.
the brainwavz molded large headphone case should work with themLooking for plain carrying case for my SONY MDR Z7M2 any sugestions? Best regards.
I use this case for Z7M2 since I threw away the box due to moving.Looking for plain carrying case for my SONY MDR Z7M2 any sugestions? Best regards.
