I don't think I'll be doing that to mine in any near future.. Esp as I don't mind the fabric material, as I said I like how it allow me to adjust the soundstage.
Question: does changing to thicker pads make the "nonexistent" clamping force tighter? If yes, can you just set the adjustment to lower position to make it back to normal?
I'm not sure how it is on the m900, but usually when a headphone has weak clamp force, you would think fatter pads would make it tighter, but its not so cut and dry.
With thick super firm pads, it would help, but with thick super squishy foam pads not so much, but a little improvement. Because the clamp is weak it just expands little more easily.
With Philips 9500, very weak clamp force, the pads was nice but i put xb1k pads, which was comfy, but sound was more distanced. Also I had to extend the headband to max as i needed to expand and get my head in. Curious about the 900s now with those thicker pads.
This whole comfort/sound battle is unique to the individual, and you'll have to experiment one way or another. The shallow pads sometimes gives the best sound for these open airy types, but one can pad roll, and enjoy slightly different signatures for different genres. This should be taken into consideration.
One thing with the sony 70mm drivers from having one type anyway and reading about them is they have great flexibility, so its fantastic to play with.
No one said the quest is easy, but its a hella fun.
Anyway the pads above with tht 900 n z7 make them both look super nice and probably very comfy, and im glad to see 70mm beasts. Tht ma900 looks pure art with that gap, and AN OPEN SONY sounds too much fun. That Hifi528 guy said it was the ULTIMATE at home listening can, and he has like a million cans lol. I like how he's a big Sony fan as well.
