jamesjames
I think I follow that. It had occurred to me that the MA900 could probably be described as semi-open - much like the T1. Do I understand correctly that you've reduced the openness by using tighter weave paper? With a slight boost in lower frequencies? The large opening at the back, of course, differentiates it from the Beyer (and most other phones). But I'm surprised in my listening by the extent to which the semi-open nature of the driver housing still seems to result in low-frequency 'fullness' - much greater, for example, than the MySphere (or the ADX5000). That said, I suspect the HD800S and ADX5000 both have greater low frequency extension. I had been thinking that the semi-open structure of the MA900 also tended to produce the slight 'boxiness' that sometimes intrudes. Your point about ear cushions with no openings, and leaving more space for resonance, is interesting too. I find this hard to predict, myself. The HD800S - with relatively low-profile cushions, is famously spacious - although the same can't be said for the ADX5000. The MySphere is probably more spacious than the ADX in my experience but has less audible low-frequency extension than the others.I think removing the resistor will leave the signal from the source, to the voice coil unchanged. Whatever the signal has to get through, and get to the voice coil. In theory, all are reduced or changed. My source is my phone. I even removed the original 3 meter cable, replacing it with another one that was only 80cm meter and smaller. What about paper, when removing the ma900. I found that it's not really an open back headphone. To be exact, it's only open about 50%.
Everyone can see that on its back, the area of the holes only for about 50% of the back area. I lined it with paper to increase this ratio to ~70%. The types of paper I use are quite tight. If brought into the dark using a light, the tiny holes are as sparse as the starry sky. Paper lining has made the ma900 a semi-open headphone. That still makes it retain the low frequencies, and the high frequencies are still bright enough. That kind of paper makes the sound full. It continues to resonate and doesn't disappear too soon...the most suitable type of ear cushion I think is the type with no holes or few holes, 20-25mm thick.
