groovyd
- Jun 29, 2012
wow that $13 cable looks perfect even though I had bought the recommended custom awhile ago...
https://eventhorizon-srv.com/ecommerce/os/catalog/product_info.php?cPath=21_27_213&products_id=5592
I decided to order the cheap one off ebay just incase. the custom I ordered above while nice has a way too thick and stiff cable for portable use so perhaps this other one is even better. thanks for highlighting this deal! hard to find replacement cables for the 7520 with locking connector. i just bought the 1.2m one even though i prefer 1.1m.
the velour beyer pads are the way to go no question however the pads you linked to I am not sure are the same ones I use. I think the model number is different. sorry but it has been a long time since i bought mine and forget exactly what model number is right. if you look back on this thread at my posts should be there somewhere.
